well let me start out by saying my pc will play bf3 crysis 2 and 3 dead space 2 and 3 sims 3 burnout paradise and mirrors edge just fine. but in bf4 i have a problem i can load up play a round then when it ends and a new rounds loads a NEW MAP it will still play fine for 3 to 5 minutes. then something starts taxing the hard drive to 99% and using 80 - 90% of my ram and my FPS will drop to like 1 fps every 15 seconds. the only thing that will fix it is a reboot. exiting bf4 and origin does not help.
i used task manager and ram map to try and locate whats using up the resources but i could not find anything.
pc spects are
amd phenom ii x4 925 at 3.6
amd 6850
8 gigs of ram (2000 mhz) running at 1354 mhz
i dont believe it to be a virus because ive dont nothing since the fresh win 8.1 reformat to get a virus. just loaded up some games via origin and installed drivers and normal things like that.
i think it could be a problem with the bios because it will no longer stay in performance mode. in fact power saver balanced and performance mode is not selected and will not stay selected. the bios also will not allow me to create a back up says it failed when i try to save the current setup or something along those lines. so im scared to try to update the bios, i cant afford to brick it at this point. some land has been passed down to me and putting everything into it.
i believe it to be the bios causing my problem but thought id ask here to be sure.
pc spects are
amd 6850
