not what i had expected
caddi daddi
Godzilla to ant hills
just ran my 6300 with 1600 ram and 2000 ram, whats up with the scores?
2nd group of uploads shows two CPU tabs and not the Memory tab.
RGone...
EDIT:
Ah hah, 1:4 vs 3:10 FSB to DRAM Ratio.
Change the Bank Cycle time to 36 or 37 on the newer ram.
END EDIT.
I had similar results when I OC'd my ram up to 2332 it actually was a bit worse.
One thing I did notice though was setting my NB at 1.4v helped the overall ram performance. I think the IMC just gets bogged down. I can put up posts from my trials if interested.
still no joy.
cpu/nb at 1.415 v.
Sorry I didn't mean at the 2332. I think it's just too much for it. I meant the higher NB volts helps in general I was eeven able to lower my Vcore. I think the IMC was struggling and needed more juice, but I don't have the best chip. I always suspected it was weak in that area.
raised the vcore a little,still no joy
spd of new stuff.
You are showing RAS to CAS of 11 but the SPD calls for RAS to CAS of 10. Need to see if you Command Rate set to 2T. It seldom makes a difference but it can. You are getting hit by the reason I don't like Corsair as well as G Skill for me on AMD.
RGone...
fighting a no boot from setting ras to cas from 11 to 10 now. It's on the slab now.
I will have it back in the bench shortly.
For some reason results on memory@1600, 1866 or even 2400 are nearly the same. The same if you use CPU-NB 2200, 2400 or 2600MHz. Simply it's waste of money to pay for faster RAM or it's waste of time to try stabilize higher CPU-NB clock as it's only raising cpu temps.
Today I've checked 1600 7-7-7, 1866 8-8-8 and 2400 10-12-11 on 2400/2600MHz CPU-NB and there was only difference in memory write transfers +/- 500MB/s. Tests on [email protected] and CHV.
I don't know if it's only my setup or it's more common but when my cpu is passing ~63*C then sometimes I see a bit lower performance like in F@H PPD count that is dropping by ~10%.
i see that in the benchmarks.
but in games and in my cad work and a huge computation, faster ram with a 2500 cpu/nb improves all of those yet scores in benchmarks either fall or no change.
my fighter sim is smoother, more detail, and no artifacts.
my cad program runs almost flawlessly.
my computation completes quicker.
is there something the benchmarks are missing?
I would compare cache transfers in AIDA64 and access time on different ratios.
I've checked only main transfers like read, write and copy. Difference in my tests was about 500-700MB/s between best and worst results and it's like nothing in daily performance.
I saw bigger difference on FX8120 than FX8320 in any memory tweaking. On FX8320 benchmark results are almost not changing no matter if I set higher or lower memory/CPU-NB clocks.
Other thing is that 3DMarks are probably worst benchmarks to compare memory performance. Try something like specview perf or some other benchmarks that use more CPU/RAM.
is cinebench of any use?
These last results were they different ram speeds?
So you did get slightly better results with I assume you mean ram/NB at the higher frequency. Or is that HT/NB if so my sweet spot seems to be 2250/2500 HT/NB
I typically use the 3D mark for my comparisons but I'm trying to optimize for gaming.
listed as cpu/nb in all my bios.
and yes it shows some improvement in cinebench.
woomack can measure no improvement, and he knows his stuff.
I have read a lot of his stuff and ya he does and I'm still confused with the cpu/nb that's one of the values but what is the other HT?
I have the sabretooth and it does have the cpu/nb but theres only one frequency
