- Nov 6, 2004
- Lawrenceville, NJ
So, I realized that I never actually had installed the nVidia drivers, so I went through the normal installation procedure (using the .19 drivers), at which point X would stop loading and crash. If I switch it back to the nv drivers, it works, but the nvidia drivers crash X on every distribution I tried, My 6800 worked perfectly in 7.04, but the 8600 crashes no matter what. I am currently running the 7.10 beta (on which the restricted driver auto-installer does not work), so any help would be appreciated.
LSPCI:
LSMOD:
LSPCI:
Code:
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
00:04.0 Multimedia audio controller: nVidia Corporation CK804 AC'97 Audio Controller (rev a2)
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev f2)
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2)
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:08.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
01:09.0 Multimedia video controller: Internext Compression Inc iTVC16 (CX23416) MPEG-2 Encoder (rev 01)
05:00.0 VGA compatible controller: nVidia Corporation GeForce 8600 GT (rev a1)
LSMOD:
Code:
Module Size Used by
ipv6 274020 10
af_packet 24840 2
rfcomm 42136 2
l2cap 26240 11 rfcomm
bluetooth 57060 4 rfcomm,l2cap
ppdev 10244 0
powernow_k8 16960 1
cpufreq_powersave 2688 0
cpufreq_stats 7232 0
cpufreq_conservative 8072 0
cpufreq_userspace 5280 0
cpufreq_ondemand 9612 1
freq_table 5792 3 powernow_k8,cpufreq_stats,cpufreq_ondemand
button 8976 0
container 5504 0
video 18060 0
sbs 19592 0
dock 10656 0
ac 6148 0
battery 11012 0
lp 12580 0
loop 19076 0
wm8775 7180 0
cx25840 26640 0
tuner 63144 0
snd_intel8x0 34972 1
snd_cmipci 37024 3
snd_ac97_codec 100644 1 snd_intel8x0
snd_usb_audio 81024 0
ac97_bus 3200 1 snd_ac97_codec
gameport 16776 1 snd_cmipci
snd_pcm_oss 44672 0
snd_opl3_lib 11520 1 snd_cmipci
snd_mpu401_uart 9600 1 snd_cmipci
snd_mixer_oss 17664 1 snd_pcm_oss
snd_seq_dummy 4740 0
snd_pcm 80388 6 snd_intel8x0,snd_cmipci,snd_ac97_codec,snd_usb_audio,snd_pcm_oss
snd_seq_oss 33152 0
snd_usb_lib 17920 1 snd_usb_audio
snd_seq_midi 9600 0
snd_seq_midi_event 8448 2 snd_seq_oss,snd_seq_midi
agpgart 35016 0
ivtv 134928 0
snd_seq 53232 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
psmouse 39952 0
snd_timer 24324 4 snd_opl3_lib,snd_pcm,snd_seq
i2c_algo_bit 7428 1 ivtv
xpad 9988 0
parport_pc 37412 1
parport 37448 3 ppdev,lp,parport_pc
snd_rawmidi 25728 3 snd_mpu401_uart,snd_usb_lib,snd_seq_midi
serio_raw 8068 0
snd_seq_device 9228 6 snd_opl3_lib,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq,snd_rawmidi
snd_hwdep 10244 2 snd_usb_audio,snd_opl3_lib
cx2341x 13316 1 ivtv
tveeprom 16784 1 ivtv
videodev 29312 1 ivtv
v4l2_common 18432 6 wm8775,cx25840,tuner,ivtv,cx2341x,videodev
v4l1_compat 15364 2 ivtv,videodev
i2c_nforce2 7040 0
k8temp 6656 0
pcspkr 4224 0
shpchp 34580 0
pci_hotplug 32704 1 shpchp
i2c_core 26112 7 wm8775,cx25840,tuner,ivtv,i2c_algo_bit,tveeprom,i2c_nforce2
snd 54660 21 snd_intel8x0,snd_cmipci,snd_ac97_codec,snd_usb_audio,snd_pcm_oss,snd_opl3_lib,snd_mpu401_uart,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_seq,snd_timer,snd_rawmidi,snd_seq_device,snd_hwdep
soundcore 8800 1 snd
snd_page_alloc 10888 2 snd_intel8x0,snd_pcm
evdev 11136 6
ext3 133768 1
jbd 60456 1 ext3
mbcache 9732 1 ext3
ide_cd 32672 0
cdrom 37536 1 ide_cd
ide_disk 18304 4
usbhid 29536 0
hid 28928 1 usbhid
floppy 60004 0
amd74xx 15260 0 [permanent]
ide_core 116548 3 ide_cd,ide_disk,amd74xx
ohci_hcd 22916 0
forcedeth 51592 0
ehci_hcd 36108 0
usbcore 138248 7 snd_usb_audio,snd_usb_lib,xpad,usbhid,ohci_hcd,ehci_hcd
sata_nv 20612 0
ata_generic 8452 0
libata 124528 2 sata_nv,ata_generic
scsi_mod 147084 1 libata
thermal 14344 0
processor 31944 2 powernow_k8,thermal
fan 5764 0
fuse 47124 3
apparmor 40600 0
commoncap 8320 1 apparmor
