Q6700 overclocking.
Shoc
Ok so I can run my cpu stable at 3.1 ghz up from the stock 2.7 but if I try to run the bus at 400mhz (so I can get the memory 1:1) I get blue screen or other errors. I've tried the same voltages I run at 3.1 to run 400mhz with a x7 multiplier in hopes of getting 2.8ghz and the 1:1 memory:cpu fsb ratio. I think my motherboard just doesn't like to run at 400mhz fsb it's a MSI P6N sli platinum. Any thoughts?
Code:
CPU-Z TXT Report
Binaries
CPU-Z version			1.58
Processors
Number of processors		1
Number of threads		4
APICs
Processor 0
	-- Core 0
		-- Thread 0	0
	-- Core 1
		-- Thread 0	1
	-- Core 2
		-- Thread 0	2
	-- Core 3
		-- Thread 0	3
Processors Information
Processor 1			ID = 0
	Number of cores		4 (max 4)
	Number of threads	4 (max 4)
	Name			Intel Core 2 Quad Q6700
	Codename		Kentsfield
	Specification		Intel(R) Core(TM)2 Quad CPU    Q6700  @ 2.66GHz
	Package (platform ID)	Socket 775 LGA (0x4)
	CPUID			6.F.B
	Extended CPUID		6.F
	Core Stepping		G0
	Technology		65 nm
	Core Speed		3100.0 MHz
	Multiplier x FSB	10.0 x 310.0 MHz
	Rated Bus speed		1240.0 MHz
	Stock frequency		2666 MHz
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
	L1 Data cache		4 x 32 KBytes, 8-way set associative, 64-byte line size
	L1 Instruction cache	4 x 32 KBytes, 8-way set associative, 64-byte line size
	L2 cache		2 x 4096 KBytes, 16-way set associative, 64-byte line size
	FID/VID Control		yes
	FID range		6.0x - 10.0x
	Max VID			1.300 V
Thread dumps
CPU Thread 0
	APIC ID			0
	Topology		Processor ID 0, Core ID 0, Thread ID 0
	Type			01008005h
	Max CPUID level		0000000Ah
	Max CPUID ext. level	80000008h
	Cache descriptor	Level 1, D, 32 KB, 1 thread(s)
	Cache descriptor	Level 1, I, 32 KB, 1 thread(s)
	Cache descriptor	Level 2, U, 4 MB, 2 thread(s)
	CPUID
	0x00000000		0x0000000A	0x756E6547	0x6C65746E	0x49656E69
	0x00000001		0x000006FB	0x00040800	0x0000E3BD	0xBFEBFBFF
	0x00000002		0x05B0B101	0x005657F0	0x00000000	0x2CB43049
	0x00000003		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000004		0x0C000121	0x01C0003F	0x0000003F	0x00000001
	0x00000004		0x0C000122	0x01C0003F	0x0000003F	0x00000001
	0x00000004		0x0C004143	0x03C0003F	0x00000FFF	0x00000001
	0x00000005		0x00000040	0x00000040	0x00000003	0x00000020
	0x00000006		0x00000001	0x00000002	0x00000001	0x00000000
	0x00000007		0x00000000	0x00000000	0x00000000	0x00000000
	0x00000008		0x00000400	0x00000000	0x00000000	0x00000000
	0x00000009		0x00000000	0x00000000	0x00000000	0x00000000
	0x0000000A		0x07280202	0x00000000	0x00000000	0x00000503
	0x80000000		0x80000008	0x00000000	0x00000000	0x00000000
	0x80000001		0x00000000	0x00000000	0x00000001	0x20000800
	0x80000002		0x65746E49	0x2952286C	0x726F4320	0x4D542865
	0x80000003		0x51203229	0x20646175	0x20555043	0x51202020
	0x80000004		0x30303736	0x20402020	0x36362E32	0x007A4847
	0x80000005		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000006		0x00000000	0x00000000	0x10008040	0x00000000
	0x80000007		0x00000000	0x00000000	0x00000000	0x00000000
	0x80000008		0x00003024	0x00000000	0x00000000	0x00000000
	MSR 0x0000001B		0x00000000	0xFEE00900
	MSR 0x0000003A		0x00000000	0x00000005
	MSR 0x00000017		0x00100000	0x88408A26
	MSR 0x000000CD		0x00000000	0x00000800
	MSR 0x0000003F		0x00000000	0x00000000
	MSR 0x000000CE		0x001B0A26	0x7F7F071A
	MSR 0x000001A0		0x00000044	0x60950489
	MSR 0x000000EE		0x00000000	0x837D4B00
	MSR 0x0000011E		0x00000000	0xBE702109
	MSR 0x0000019C		0x00000000	0x88370000
	MSR 0x00000198		0x0A260A26	0x06000A26
	MSR 0x00000199		0x00000000	0x00000A26
CPU Thread 1
	APIC ID			1
	Topology		Processor ID 0, Core ID 1, Thread ID 0
	Type			01008005h
	CPUID
	0x00000001		0x000006FB	0x01040800	0x0000E3BD	0xBFEBFBFF
	MSR 0x0000001B		0x00000000	0xFEE00800
	MSR 0x000001A0		0x00000044	0x60950481
	MSR 0x0000019C		0x00000000	0x88380000
CPU Thread 2
	APIC ID			2
	Topology		Processor ID 0, Core ID 2, Thread ID 0
	Type			01008005h
	CPUID
	0x00000001		0x000006FB	0x02040800	0x0000E3BD	0xBFEBFBFF
	MSR 0x0000019C		0x00000000	0x883C0000
CPU Thread 3
	APIC ID			3
	Topology		Processor ID 0, Core ID 3, Thread ID 0
	Type			01008005h
	CPUID
	0x00000001		0x000006FB	0x03040800	0x0000E3BD	0xBFEBFBFF
	MSR 0x0000019C		0x00000000	0x883A0000
Chipset
Northbridge			NVIDIA nForce 650i SLI SPP rev. A2
Southbridge			NVIDIA nForce 650i SLI MCP rev. A3
Graphic Interface		PCI-Express
PCI-E Link Width		x4
PCI-E Max Link Width		x16
Memory Type			DDR2
Memory Size			4096 MBytes
Channels			Dual
Memory Frequency		398.6 MHz (7:9)
CAS# latency (CL)		5.0
RAS# to CAS# delay (tRCD)	5
RAS# Precharge (tRP)		5
Cycle Time (tRAS)		18
Bank Cycle Time (tRC)		23
Command Rate (CR)		2T
Memory SPD
DIMM #				1
	SMBus address		0x50
	Memory type		DDR2
	Module format		Regular UDIMM
	Manufacturer (ID)	Mushkin (7F7F7F94FFFFFFFF)
	Size			1024 MBytes
	Max bandwidth		PC2-6400 (400 MHz)
	Part number		991533 (996533)
	Manufacturing date	Week 10/Year 07
	Number of banks		2
	Data width		64 bits
	Correction		None
	Nominal Voltage		1.80 Volts
	EPP			yes (1 profiles)
	XMP			no
JEDEC timings table		CL-tRCD-tRP-tRAS-tRC @ frequency
	JEDEC #1		4.0-4-4-12-16 @ 266 MHz
	JEDEC #2		5.0-5-5-18-23 @ 400 MHz
EPP timings table		CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
	EPP profile #1 (abb)	4.0-5-4-11-xx-2T- @ 400 MHz (2.100 Volts)
DIMM #				2
	SMBus address		0x51
	Memory type		DDR2
	Size			1024 MBytes
	Number of banks		2
	Data width		64 bits
	Correction		None
	XMP			no
DIMM #				3
	SMBus address		0x52
	Memory type		DDR2
	Size			1024 MBytes
	Number of banks		2
	Data width		64 bits
	Correction		None
	XMP			no
DIMM #				4
	SMBus address		0x53
	Memory type		DDR2
	Size			1024 MBytes
	Number of banks		2
	Data width		64 bits
	Correction		None
	XMP			no
DIMM #				1
SPD registers
		00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
	00	80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
	10	0C 04 30 01 02 00 07 3D 50 00 00 32 1E 32 2D 80
	20	17 25 05 12 3C 1E 1E 00 30 39 69 80 14 1E 00 00
	30	00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 A4
	40	7F 7F 7F 94 FF FF FF FF 01 39 39 31 35 33 33 20
	50	28 39 39 36 35 33 33 29 00 00 00 00 00 07 0A 00
	60	00 00 00 6D 56 4E A1 10 8C 25 10 32 28 1B 00 00
	70	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	80	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	90	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	A0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	B0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	C0	FF FF FF FF FF FF FF FF DA FF FF FF FF FF FF FF
	D0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	E0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	F0	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0F
DIMM #				2
SPD registers
DIMM #				3
SPD registers
DIMM #				4
SPD registers
Monitoring
Mainboard Model		MS-7350 (0x0000019C - 0x005F1CD0)
LPCIO
LPCIO Vendor		Fintek
LPCIO Model		F71882F
LPCIO Vendor ID		0x1934
LPCIO Chip ID		0x541
Config Mode I/O address	0x4E
Config Mode LDN		0x4
Config Mode registers
	00	FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
	10	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	20	05 41 20 19 34 00 80 5E 00 00 00 00 08 0E 00 00
	30	01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	40	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	50	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	60	0A 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	70	00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space		LPC, base address = 0x0A00
Hardware Monitors
Hardware monitor	Fintek F71882F
	Voltage 0	3.25 Volts [0xCB] (+3.3V)
	Voltage 1	1.26 Volts [0x9E] (CPU VCORE)
	Voltage 2	1.84 Volts [0x73] (VIN2)
	Voltage 3	1.02 Volts [0x57] (VIN3)
	Voltage 4	4.88 Volts [0x74] (+5V)
	Voltage 5	12.06 Volts [0x89] (+12V)
	Voltage 6	1.79 Volts [0x70] (VIN6)
	Voltage 7	3.22 Volts [0xC9] (VSB3V)
	Voltage 8	2.91 Volts [0xB6] (VBAT)
	Temperature 0	33°C (91°F) [0x21] (TMPIN0)
	Temperature 1	33°C (91°F) [0x21] (TMPIN1)
	Fan 0		1779 RPM [0x34B] (FANIN0)
	Fan 1		1406 RPM [0x42B] (FANIN1)
	Fan 2		6726 RPM [0xDF] (FANIN2)
	Fan PWM 0	100 pc [0xFF] (CPU)
	Fan PWM 1	100 pc [0xFF] (System Fan 1)
	Fan PWM 2	100 pc [0xFF] (System Fan 2)
	Fan PWM 3	100 pc [0xFF] (System Fan 3)
	00	FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00
	10	00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
	20	CB 9F 74 58 74 89 71 C9 B7 FF FF FF FF FF FF FF
	30	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
	50	FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
	60	00 00 00 00 FF FF 02 78 00 00 FF 0E 40 24 FF 08
	70	FF FF 21 FF 21 FF 80 FF FF FF FF FF FF FF FF FF
	80	FF FF 4B 4B 64 55 55 46 FF FF FF FF FF FF A8 FF
	90	00 08 08 00 02 FF FF FF 42 24 FF AA 55 55 FF 0A
	A0	03 37 00 FF 01 87 3C 32 28 1E FF D9 B2 99 80 0D
	B0	04 2B 00 FF 02 11 3C 32 28 1E FF D9 B2 99 80 0E
	C0	00 DF 00 FF 00 71 3C 32 28 1E FF D9 B2 99 80 0F
	D0	0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
	F0	00 00 00 00 00 00 37 FF 01 72 FF 00 FF FF FF FF
Hardware monitor	NVIDIA NVAPI
	Voltage 0	1.08 Volts [0x433] (VIN0)
	Temperature 0	41°C (105°F) [0x29] (TMPIN0)
	Fan 0		1620 RPM [0x654] (FANIN0)
	Fan PWM 0	41 pc [0x29] (FANPWMIN0)
PCI Devices
Description			Host Bridge
Location			bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03A3
	Revision ID		0xA2
	PI			0x00
	SubClass		0x00
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps class		HyperTransport
	Caps offset		0x40
	Caps revision		0.16
	Interface type		Host/Secondary
	Device number		0
	Link 0 width (in/out)	8 bits/8 bits
	Link 0 frequency	400 MHz
PCI registers
	00	DE 10 A3 03 06 00 B0 00 A2 00 00 06 00 00 80 00
	10	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
	40	08 00 01 20 22 00 00 00 10 32 3F 00 03 01 00 00
	50	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	21 49 44 44 13 01 00 00 00 00 00 00 10 00 00 00
	70	07 05 22 00 00 00 00 00 81 01 85 01 00 00 00 00
	80	00 00 00 00 00 00 00 00 70 00 00 80 00 00 00 00
	90	1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
	B0	CB 10 00 06 F0 F0 00 00 00 00 00 00 00 00 00 00
	C0	11 11 01 00 01 33 33 13 03 00 00 00 00 50 07 00
	D0	01 0A 00 00 00 00 00 00 FF FF 70 07 10 00 00 00
	E0	08 00 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
	F0	00 E4 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
Description			RAM Memory Controller
Location			bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AC
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 AC 03 00 00 20 00 A1 00 00 05 00 00 80 00
	30	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	40	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	50	00 00 00 00 21 21 16 00 11 11 00 00 04 00 00 00
	60	21 08 12 06 DE 8F E1 1F 08 42 48 18 22 8F 00 20
	70	10 32 54 0A 10 00 00 00 20 00 00 00 2F 00 3D 01
	80	00 00 00 00 05 00 00 00 00 00 50 3F 90 7F 00 00
	90	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	A0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 01 00 00 00 80 F9 FD 00
	E0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 C7 02 28 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 0 (0x00), function 2 (0x02)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AA
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 AA 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	00 00 00 00 37 BA 20 81 00 00 02 00 37 BA 12 00
	50	00 00 00 00 00 00 00 00 00 00 00 00 02 00 02 22
	60	27 01 10 CE FF FF 00 00 31 01 46 00 FF FF 00 00
	70	31 01 8C 00 97 00 10 80 03 2C 1C 80 03 2C 1C 00
	80	00 00 00 80 4A 01 00 00 DD DD DD 0D 00 00 00 00
	90	F0 FD 07 00 F8 01 F8 01 06 00 00 00 00 00 00 00
	B0	00 00 00 00 01 20 00 12 0D 00 00 00 31 65 07 00
	C0	FF FF FF FF FF FF FF BF 00 00 00 00 99 80 CC 00
	D0	00 21 09 00 01 00 00 00 00 00 00 00 00 00 00 00
	E0	80 00 EE 00 13 0A 00 00 80 00 08 A1 65 1A 12 00
	F0	1B 1B 1B 1B 00 FF 21 00 BB BB BB BB 00 00 0F 80
Location			bus 0 (0x00), device 0 (0x00), function 3 (0x03)
Common header
	Vendor ID		0x10DE
	Model ID		0x03A9
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 A9 03 06 00 A0 00 A1 00 00 05 00 00 00 00
	30	00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
	40	00 00 00 00 00 00 00 00 04 20 1C 90 04 20 1C A0
	50	04 18 1C 90 04 20 1C 90 04 28 1C 90 04 18 1C 80
	60	04 20 1C 80 04 28 1C 80 04 30 1C 80 04 38 1C 80
	70	02 20 1C 80 1F 20 00 C0 00 00 00 00 00 00 00 00
	80	00 00 00 00 C9 20 54 F7 02 1F 1C 80 40 10 00 40
	90	8D DA 01 09 00 00 00 00 11 00 00 00 00 00 00 00
	A0	00 00 80 99 80 00 00 00 19 00 A8 61 00 00 00 00
	B0	00 00 00 00 82 20 00 00 00 00 02 00 01 8C 01 8C
	C0	FF FF FF FF 00 00 00 00 10 00 00 00 00 00 00 00
	D0	00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 10 10 18 00 00 40 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 0 (0x00), function 4 (0x04)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AB
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 AB 03 06 00 A0 00 A1 00 00 05 00 00 00 00
	50	22 88 10 04 22 80 02 0A A0 00 02 0A A1 10 42 0A
	60	85 08 11 08 84 08 31 02 22 90 B5 18 8C 31 A5 1C
	70	6B A5 B4 12 29 31 81 0E E7 1C 84 0C C5 98 94 10
	80	89 B4 06 21 62 00 30 08 00 00 00 00 00 00 00 00
	90	C5 80 01 00 43 08 01 00 00 00 00 00 00 00 00 00
	A0	0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00
	E0	01 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 0 (0x00), function 5 (0x05)
Common header
	Vendor ID		0x10DE
	Model ID		0x03A8
	Revision ID		0xA2
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 A8 03 04 00 A0 00 A2 00 00 05 00 00 80 00
	40	00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	80	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 0 (0x00), function 6 (0x06)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B5
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 B5 03 02 00 20 00 A1 00 00 05 00 00 80 00
	40	00 F0 0F 3F 00 00 00 00 00 00 00 00 00 00 00 00
	50	03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 0 (0x00), function 7 (0x07)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B4
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 B4 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	00 00 00 00 00 00 00 00 00 00 00 00 11 00 00 00
	50	00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
	B0	FF FF FF FF FF FF FF FF 10 21 00 00 AC 00 20 00
	C0	10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AD
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 AD 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	00 01 00 00 3F 44 04 00 00 00 00 00 00 00 00 00
	50	08 F8 F0 A0 0C 0C 04 7E 0C 00 00 00 02 2B 7F 04
	60	65 00 52 00 00 00 00 00 00 00 00 00 33 00 20 00
	70	47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	80	3F 63 00 00 00 08 00 00 00 00 00 00 00 2A 12 55
	90	35 C9 23 30 60 A5 95 45 0D 2E 22 76 03 05 33 0E
	A0	00 00 17 17 F0 11 03 00 20 00 27 05 00 00 00 00
	B0	00 80 00 80 00 80 00 80 00 80 00 80 00 80 00 80
	D0	31 26 61 24 31 26 61 24 31 26 61 24 31 26 61 24
	E0	03 00 00 00 10 08 71 0F F1 01 00 00 11 11 70 11
	F0	10 18 FF 08 08 10 03 04 01 00 00 00 63 03 77 40
Location			bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AE
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 AE 03 00 00 20 00 A1 00 00 05 00 00 80 00
	50	00 00 00 00 FF FF 07 00 00 00 00 00 6A 8E 00 00
	60	0C 0C 03 03 C0 C0 30 30 0E 0E 0B 0B E0 E0 B0 B0
	70	01 08 A0 CE 01 08 A0 CE 01 08 A0 CE 01 08 A0 CE
	80	01 08 00 16 21 42 F0 03 18 28 80 00 20 60 70 00
	90	13 00 00 10 1F 10 00 08 1F 20 00 08 00 20 00 08
	A0	00 20 00 08 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 00 00 00 00 04 10 00 00 00 00 00 00
	C0	00 00 00 00 15 06 82 81 30 00 00 00 01 01 00 00
	D0	5A 08 00 01 44 00 10 00 00 00 20 00 00 00 30 00
	E0	1B 73 03 00 9B 73 03 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
	Vendor ID		0x10DE
	Model ID		0x03AF
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 AF 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	D0 00 00 00 00 00 00 00 6C 1B 54 84 81 03 00 06
	50	54 00 01 00 47 00 08 13 FF FF FF FF FF FF FF FF
	60	FF FF 03 04 0E 00 00 00 2A 80 87 00 00 00 00 00
	70	01 01 01 01 08 00 B1 3C 0A 22 07 07 50 00 F2 02
	80	95 13 00 00 21 F2 CE FB E1 00 50 00 00 00 00 00
	90	08 00 3F 70 08 00 1F 0C 08 0F 17 00 08 0F 18 00
	A0	50 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00
	F0	FF FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 1 (0x01), function 3 (0x03)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B0
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 B0 03 00 00 20 00 A1 00 00 05 00 00 80 00
	50	FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	60	31 51 00 00 44 44 00 00 44 44 00 00 44 44 00 00
	70	44 44 00 00 44 44 00 00 44 44 00 00 AA AA AA AA
	80	AA AA BB BB 00 30 00 00 00 00 00 00 00 00 00 00
	90	00 00 00 00 33 33 33 33 33 33 33 33 99 99 99 99
	A0	22 22 22 22 AE 0A E0 00 08 08 0C 0E 08 08 08 08
	B0	08 08 0A 0A 0A 09 08 08 00 01 02 00 00 07 00 00
	C0	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	D0	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	E0	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	F0	00 07 00 00 00 07 00 00 00 07 00 00 00 00 00 00
Location			bus 0 (0x00), device 1 (0x01), function 4 (0x04)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B1
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 B1 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	73 7F 00 00 FF FF 03 00 98 3A 30 80 80 01 00 02
	50	00 00 00 00 1F 1F 00 00 0F 0F 0F 0F F0 F1 41 00
	60	0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F F0 F1 41 00
	70	0F 0F 0F 0F 0F 0F 0F 0F 07 00 00 00 0F 0F 00 00
	80	0F 0F 00 00 F0 F1 41 00 0F 0F 0F 0F 0F 0F 0F 0F
	90	0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F
	A0	0F 0F 0F 0F F0 F1 41 02 0F 0F 0F 0F 0F 0F 0F 0F
	B0	06 02 00 00 44 44 44 11 44 44 44 44 44 44 44 00
	C0	00 00 00 04 00 00 00 04 00 00 00 00 00 00 00 00
	D0	00 00 00 00 0F 0F 00 00 0F 0F 00 00 00 00 00 00
	E0	00 00 00 00 00 00 00 00 44 00 00 00 44 00 00 00
	F0	FF FF 00 02 00 00 00 00 0F 0F 0F 0F 0F 0F 0F 0F
Location			bus 0 (0x00), device 1 (0x01), function 5 (0x05)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B2
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 B2 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	F9 01 A0 0A 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 1 (0x01), function 6 (0x06)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B3
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 B3 03 00 00 20 00 A1 00 00 05 00 00 80 00
	40	00 00 00 00 33 33 33 33 00 00 00 00 33 33 33 33
	70	00 00 00 00 00 00 00 00 00 07 00 00 00 07 00 00
	80	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	90	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	A0	00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
	B0	00 07 00 00 00 07 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 07 07 07 07 88 88 88 88 88 88 88 88
	D0	00 00 00 00 00 00 00 00 40 40 40 40 88 88 77 00
	F0	00 00 00 00 88 88 88 88 88 88 88 88 00 01 02 00
Location			bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B6
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 B6 03 00 00 20 00 A1 00 00 05 00 00 80 00
	50	00 08 00 00 00 00 20 00 00 00 00 00 00 00 00 00
	70	EE 03 41 DC 21 7B CB 20 87 0F 86 AA F2 C8 69 C8
	80	1D 62 1E 32 F9 7D 52 E5 56 3D F1 E3 53 F5 EF F7
	90	6E EF FC 5B F6 BD 7A DE 3F E7 DF 55 F7 F2 FF 75
	A0	6D 5F F7 FE DF B3 F7 D2 79 E1 7B 57 AC FB FD 7F
	B0	7F DF F7 8E FF A7 7B FA 77 FF EF FF BB F7 7E BE
	C0	44 BF 28 D3 45 F1 05 CE B2 2D 39 22 10 88 A0 81
	D0	A5 52 5F D3 BE DA A1 43 4F 10 B9 47 00 00 00 00
Location			bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x03BC
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 BC 03 06 00 A0 00 A1 00 00 05 00 00 00 00
Location			bus 0 (0x00), device 2 (0x02), function 2 (0x02)
Common header
	Vendor ID		0x10DE
	Model ID		0x03BA
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x0000
	Subsystem ID		0x0000
	Int. Line		0xFF
	Int. Pin		0x00
PCI registers
	00	DE 10 BA 03 00 00 20 00 A1 00 00 05 00 00 80 00
	70	FF FF 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
	90	44 44 44 11 44 44 44 44 44 44 44 00 00 00 00 04
	A0	00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00
	B0	44 44 44 00 44 04 44 04 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 44 44 44 00 44 04 44 04
	E0	40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40
Description			PCI to PCI Bridge
Location			bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B7
	Revision ID		0xA1
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x10
	Latency			0x00
	Header			0x01
PCI header
	Primary bus		0x00
	Secondary bus		0x01
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps class		Subsystem Vendor
	Caps offset		0x40
	SubVendor ID		0x10DE
	SubSystem ID		0x0C55
PCI capability
	Caps class		Power Management
	Caps offset		0x48
	Caps version		1.1
PCI capability
	Caps class		Message Signalled Interrupts
	Caps offset		0x50
PCI capability
	Caps offset		0x60
	Interface type		MSI Mapping
PCI capability
	Caps class		PCI Express
	Caps offset		0x80
	Device type		Root Port of PCI-E Root Complex
	Port			0
	Version			1.0
	Physical slot		#0
	Presence detect		yes
	Link width		4x (max 16x)
Extended capabilities
	Caps class		Virtual Channel
	Caps offset		0x100
PCI registers
	00	DE 10 B7 03 07 04 10 00 A1 00 04 06 10 00 01 00
	10	00 00 00 00 00 00 00 00 00 01 01 00 C1 C1 00 20
	20	00 FC 90 FE 01 D4 F1 DF 00 00 00 00 00 00 00 00
	30	00 00 00 00 40 00 00 00 00 00 00 00 00 00 1A 00
	40	0D 48 00 00 DE 10 55 0C 01 50 02 F8 00 00 00 00
	50	05 60 93 00 0C F0 E0 FE 00 00 00 00 B2 49 00 00
	60	08 80 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
	80	10 00 41 01 01 80 00 00 10 28 00 00 01 35 11 00
	90	00 00 41 30 00 00 00 00 C0 01 48 01 00 00 00 00
	100	02 00 01 00 00 00 00 00 00 00 00 00 02 00 00 00
	110	00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
	120	00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
	130	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03B9
	Revision ID		0xA1
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x10
	Latency			0x00
	Header			0x01
PCI header
	Primary bus		0x00
	Secondary bus		0x02
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0x40
	SubVendor ID		0x10DE
	SubSystem ID		0x0C55
PCI capability
	Caps offset		0x48
	Caps version		1.1
PCI capability
	Caps offset		0x50
PCI capability
	Caps offset		0x60
PCI capability
	Caps offset		0x80
	Port			3
	Version			1.0
	Physical slot		#0
	Presence detect		yes
	Link width		1x (max 1x)
	Caps offset		0x100
PCI registers
	00	DE 10 B9 03 07 04 10 00 A1 00 04 06 10 00 01 00
	10	00 00 00 00 00 00 00 00 00 02 02 00 D1 D1 00 00
	20	A0 FE A0 FE F1 FF 01 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
	50	05 60 93 00 0C F0 E0 FE 00 00 00 00 A2 49 00 00
	80	10 00 41 01 01 80 00 00 10 28 00 00 11 34 11 03
	90	00 00 11 30 00 00 00 00 C0 01 49 01 00 00 00 00
Location			bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x03BB
	Revision ID		0xA1
	PI			0x00
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x10
	Latency			0x00
	Header			0x01
PCI header
	Primary bus		0x00
	Secondary bus		0x03
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0x40
	SubVendor ID		0x10DE
	SubSystem ID		0x0C55
PCI capability
	Caps offset		0x48
	Caps version		1.1
PCI capability
	Caps offset		0x50
PCI capability
	Caps offset		0x60
PCI capability
	Caps offset		0x80
	Port			2
	Version			1.0
	Physical slot		#0
	Presence detect		yes
	Caps offset		0x100
PCI registers
	00	DE 10 BB 03 04 04 10 00 A1 00 04 06 10 00 01 00
	10	00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
	20	F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
	50	05 60 93 00 0C F0 E0 FE 00 00 00 00 92 49 00 00
	80	10 00 41 01 01 80 00 00 10 28 00 00 11 34 11 02
	90	00 00 11 10 00 00 00 00 C0 01 48 00 00 00 00 00
Location			bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0270
	Revision ID		0xA2
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0x44
	Caps revision		1.03
	Interface type		Slave/Primary
	Link 0 frequency	200 MHz
	Link 1 width (in/out)	8 bits/8 bits
	Link 1 frequency	200 MHz
PCI capability
	Caps offset		0xE0
PCI registers
	00	DE 10 70 02 06 00 B0 00 A2 00 00 05 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 62 14 50 73
	30	00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
	40	62 14 50 73 08 E0 E9 01 22 20 00 00 D0 00 00 00
	50	23 00 7F 80 03 00 00 00 00 00 03 00 00 00 00 00
	60	00 00 00 00 00 00 00 00 00 00 00 00 06 06 05 00
	70	44 44 44 00 50 01 00 00 11 00 00 00 11 11 55 00
	80	23 55 55 00 FA 00 64 0C 03 00 00 00 7F 00 00 00
	90	70 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00
	E0	08 00 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
Description			PCI to ISA Bridge
Location			bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0260
	Revision ID		0xA3
	PI			0x00
	SubClass		0x01
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (port)	0x00004F00
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 60 02 0F 00 A0 00 A3 00 01 06 00 00 80 00
	10	01 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	40	62 14 50 73 00 00 00 00 FA 3E FF 00 FA 3E FF 00
	50	FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FE BF
	60	00 00 00 00 00 00 00 00 00 00 00 00 00 00 F9 FF
	70	10 00 FF FF C9 00 00 00 00 00 45 19 00 40 43 03
	80	09 20 00 D2 01 81 00 00 C0 00 00 01 00 00 00 00
	90	00 00 00 00 00 00 00 00 21 47 65 B7 EF CD 00 00
	A0	01 00 10 80 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 00 0A 7F 0A 00 00 00 00 00 00 00 00
	D0	00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
	F0	00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
Description			SMBus Controller
Location			bus 0 (0x00), device 10 (0x0A), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x0264
	Revision ID		0xA3
	PI			0x00
	SubClass		0x05
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 4 (port)	0x00005000
	Address 5 (port)	0x00006000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x0B
	Int. Pin		0x01
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI registers
	00	DE 10 64 02 01 00 B0 00 A3 00 05 0C 00 00 80 00
	20	01 50 00 00 01 60 00 00 00 00 00 00 62 14 50 73
	30	00 00 00 00 44 00 00 00 00 00 00 00 0B 01 00 00
	40	62 14 50 73 01 00 02 C0 00 00 00 00 00 00 00 00
	60	01 40 00 00 01 44 00 00 01 48 00 00 00 00 00 00
	70	01 00 00 00 00 00 00 00 00 00 00 00 01 20 00 00
	C0	D4 30 80 01 00 00 00 00 00 00 00 00 00 00 00 00
	E0	10 10 04 00 00 A0 00 00 80 30 00 00 46 44 44 11
	F0	5A FF 5F BF 00 00 00 C0 10 00 00 00 00 00 00 00
Location			bus 0 (0x00), device 10 (0x0A), function 2 (0x02)
Common header
	Vendor ID		0x10DE
	Model ID		0x0272
	Revision ID		0xA3
	PI			0x00
	SubClass		0x00
	BaseClass		0x05
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x00
	Int. Pin		0x00
PCI registers
	00	DE 10 72 02 00 04 A0 00 A3 00 00 05 00 00 80 00
	40	00 00 00 00 00 00 00 00 10 00 00 10 00 00 10 10
	50	10 10 10 10 00 00 00 00 00 00 00 00 00 00 00 00
	60	02 03 00 00 12 00 00 00 02 00 00 00 10 01 12 00
	70	32 33 00 00 03 00 00 00 00 00 00 00 12 01 00 00
	80	10 00 00 00 00 00 00 00 00 00 00 00 30 02 00 00
	90	00 00 00 00 01 20 00 00 01 00 00 00 00 09 00 00
	A0	01 02 00 00 00 10 00 00 05 00 00 00 01 00 00 00
	B0	00 10 00 80 01 00 00 80 00 00 00 00 02 00 00 00
	C0	07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description			USB Controller (OHCI)
Location			bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x026D
	Revision ID		0xA3
	PI			0x10
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFBFFB000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x17
	Int. Pin		0x01
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI registers
	00	DE 10 6D 02 06 00 B0 00 A3 10 03 0C 00 00 80 00
	10	00 B0 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 44 00 00 00 00 00 00 00 17 01 03 01
	40	62 14 50 73 01 00 02 FE 00 00 00 00 00 00 00 00
	50	0E 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
Description			USB 2.0 Controller (EHCI)
Location			bus 0 (0x00), device 11 (0x0B), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x026E
	Revision ID		0xA3
	PI			0x20
	SubClass		0x03
	BaseClass		0x0C
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFBFFAC00
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x16
	Int. Pin		0x02
PCI capability
	Caps class		Debug Port
	Caps offset		0x44
PCI capability
	Caps offset		0x80
	Caps version		1.1
PCI registers
	00	DE 10 6E 02 06 00 B0 00 A3 20 03 0C 00 00 80 00
	10	00 AC FF FB 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 44 00 00 00 00 00 00 00 16 02 03 01
	40	62 14 50 73 0A 80 98 20 00 00 00 00 00 00 00 00
	60	20 20 01 00 00 60 18 85 03 3C 0A 01 00 00 00 00
	70	00 00 08 05 00 10 20 80 89 3D B6 22 77 25 04 00
	80	01 00 02 FE 00 80 00 00 00 00 00 00 15 16 00 00
	A0	01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
	B0	33 00 11 22 00 00 00 00 FF 00 00 00 00 00 00 00
	C0	10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
Description			IDE Controller
Location			bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0265
	Revision ID		0xA1
	PI			0x8A
	SubClass		0x01
	BaseClass		0x01
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 4 (port)	0x0000FFA0
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI registers
	00	DE 10 65 02 05 00 B0 00 A1 8A 01 01 00 00 00 00
	20	A1 FF 00 00 00 00 00 00 00 00 00 00 62 14 50 73
	30	00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
	40	62 14 50 73 01 00 02 00 00 00 00 00 00 00 00 00
	50	03 F0 01 00 00 00 00 00 A8 A8 A8 A8 FF 00 FF FF
Description			RAID Controller
Location			bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0266
	Revision ID		0xA1
	PI			0x85
	SubClass		0x04
	BaseClass		0x01
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (port)	0x0000B800
	Address 1 (port)	0x0000B480
	Address 2 (port)	0x0000B400
	Address 3 (port)	0x0000B080
	Address 4 (port)	0x0000B000
	Address 5 (memory)	0xFBFF9000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x15
	Int. Pin		0x01
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI capability
	Caps offset		0xB0
PCI capability
	Caps offset		0xCC
PCI registers
	00	DE 10 66 02 07 00 B0 00 A1 85 04 01 00 00 00 00
	10	01 B8 00 00 81 B4 00 00 01 B4 00 00 81 B0 00 00
	20	01 B0 00 00 00 90 FF FB 00 00 00 00 62 14 50 73
	30	00 00 00 00 44 00 00 00 00 00 00 00 15 01 03 01
	40	62 14 50 73 01 B0 02 00 00 00 00 00 00 00 00 00
	50	07 00 00 00 00 00 00 00 00 20 00 20 44 20 00 20
	60	00 C6 00 C7 51 0C 00 00 00 0F 06 42 00 00 00 00
	70	2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
	80	00 00 00 C0 00 C0 1D BF 00 00 AC 80 22 F2 31 B4
	90	00 00 95 13 00 00 00 00 06 00 06 10 00 00 04 01
	A0	14 10 00 2A 80 00 00 00 00 00 00 00 33 33 00 02
	B0	05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
	C0	00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
	D0	0A 00 02 0C 42 00 00 00 00 00 00 00 02 55 00 E4
	E0	0A 00 02 0A 42 00 00 00 00 00 00 00 A0 E0 10 80
	F0	00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
Location			bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0267
	Revision ID		0xA1
	PI			0x85
	SubClass		0x04
	BaseClass		0x01
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (port)	0x0000AC00
	Address 1 (port)	0x0000A880
	Address 2 (port)	0x0000A800
	Address 3 (port)	0x0000A480
	Address 4 (port)	0x0000A400
	Address 5 (memory)	0xFBFF8000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x16
	Int. Pin		0x01
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI capability
	Caps offset		0xB0
PCI capability
	Caps offset		0xCC
PCI registers
	00	DE 10 67 02 07 00 B0 00 A1 85 04 01 00 00 00 00
	10	01 AC 00 00 81 A8 00 00 01 A8 00 00 81 A4 00 00
	20	01 A4 00 00 00 80 FF FB 00 00 00 00 62 14 50 73
	30	00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
	60	00 C7 00 C7 51 0C 00 00 00 0F 06 42 00 00 00 00
	80	00 00 00 C0 00 B0 C9 2D 00 00 C4 B0 00 D0 3D 2E
	90	00 00 14 81 00 00 00 00 06 00 06 10 00 00 04 01
	A0	14 10 00 2C 83 00 00 00 00 00 00 00 33 33 00 02
	D0	0A 00 02 0C 42 00 00 00 00 00 00 00 0F 00 80 E7
	E0	0A 00 02 0C 42 00 00 00 00 00 00 00 02 00 E0 E7
Location			bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x026F
	Revision ID		0xA2
	PI			0x01
	SubClass		0x04
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x81
PCI header
	Primary bus		0x00
	Secondary bus		0x04
	Int. Line		0x00
	Int. Pin		0x00
PCI capability
	Caps offset		0xB8
	SubVendor ID		0x10DE
	SubSystem ID		0xCB84
PCI capability
	Caps offset		0x8C
PCI registers
	00	DE 10 6F 02 07 04 B0 00 A2 01 04 06 00 00 81 00
	10	00 00 00 00 00 00 00 00 00 04 04 40 E0 E0 80 02
	20	B0 FE B0 FE F0 FF 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
	40	00 00 03 00 01 00 02 00 05 00 00 00 00 00 4C 00
	50	00 00 FE BF 00 00 00 00 FF 1F FF 1F 00 00 00 00
	70	00 00 00 00 00 00 00 00 00 00 FE 3F 01 00 00 00
	80	00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 A8
	90	00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
	A0	04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
	B0	00 00 00 00 FF FF 00 00 0D 8C 00 00 DE 10 84 CB
	C0	DE 10 84 CB 03 00 00 00 00 00 00 00 00 00 00 00
Description			Multimedia device
Location			bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x026C
	Revision ID		0xA2
	PI			0x00
	SubClass		0x03
	BaseClass		0x04
	Cache Line		0x00
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFBFF4000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x14
	Int. Pin		0x02
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI capability
	Caps offset		0x50
PCI capability
	Caps offset		0x6C
PCI registers
	00	DE 10 6C 02 06 00 B0 00 A2 00 03 04 00 00 80 00
	10	00 40 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 44 00 00 00 00 00 00 00 14 02 02 05
	40	62 14 50 73 01 50 02 C0 00 00 00 00 01 01 0F 00
	50	05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
	60	00 00 00 00 00 00 00 00 0F 00 00 00 08 00 02 A8
	F0	00 00 00 00 00 00 00 46 00 29 00 00 00 00 00 00
Description			Bridge device
Location			bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x0269
	Revision ID		0xA3
	PI			0x00
	SubClass		0x80
	BaseClass		0x06
	Cache Line		0x00
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFBFF3000
	Subvendor ID		0x1462
	Subsystem ID		0x7350
	Int. Line		0x17
	Int. Pin		0x01
PCI capability
	Caps offset		0x44
	Caps version		1.1
PCI registers
	00	DE 10 69 02 06 00 B0 00 A3 00 80 06 00 00 00 00
	10	00 30 FF FB 01 00 00 00 00 00 00 00 00 00 00 00
	30	00 00 00 00 44 00 00 00 00 00 00 00 17 01 01 14
	40	62 14 50 73 01 00 02 FE 00 01 00 00 0B 00 00 10
	50	05 6C 84 01 00 00 00 00 00 00 00 00 00 00 00 00
	F0	00 00 00 00 11 00 00 00 42 01 00 00 00 00 00 00
Description			VGA Controller
Location			bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x10DE
	Model ID		0x1244
	Revision ID		0xA1
	PI			0x00
	SubClass		0x00
	BaseClass		0x03
	Cache Line		0x10
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFC000000
	Address 1 (memory)	0xD8000000
	Address 3 (memory)	0xD4000000
	Address 5 (port)	0x0000CC00
	Subvendor ID		0x196E
	Subsystem ID		0x089C
	Int. Line		0x10
	Int. Pin		0x01
PCI capability
	Caps offset		0x60
	Caps version		1.2
PCI capability
	Caps offset		0x68
PCI capability
	Caps offset		0x78
	Device type		PCI-E Endpoint Device
	Port			0
	Version			2.0
PCI capability
	Caps class		Vendor Dependant
	Caps offset		0xB4
	Caps offset		0x100
	Caps class		Power Budgeting
	Caps offset		0x128
	Caps class		Vendor Specific
	Caps offset		0x600
	Vendor ID		1
	Size			36
PCI registers
	00	DE 10 44 12 07 00 10 00 A1 00 00 03 10 00 80 00
	10	00 00 00 FC 0C 00 00 D8 00 00 00 00 0C 00 00 D4
	20	00 00 00 00 01 CC 00 00 00 00 00 00 6E 19 9C 08
	30	00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
	40	6E 19 9C 08 00 00 00 00 00 00 00 00 00 00 00 00
	50	01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
	60	01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 10 B4 02 00 A0 8D 00 00
	80	10 29 00 00 01 4D 05 00 00 01 41 10 00 00 00 00
	90	00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
	A0	00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
	B0	00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
	100	02 00 81 12 00 00 00 00 00 00 00 00 00 00 00 00
	120	00 00 00 00 00 00 00 00 04 00 01 60 00 00 00 00
	130	21 81 07 00 00 00 00 00 00 00 00 20 00 00 FF 63
Location			bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
	Vendor ID		0x10DE
	Model ID		0x0BEE
	Revision ID		0xA1
	PI			0x00
	SubClass		0x03
	BaseClass		0x04
	Cache Line		0x10
	Latency			0x00
	Header			0x80
PCI header
	Address 0 (memory)	0xFE97C000
	Subvendor ID		0x196E
	Subsystem ID		0x089C
	Int. Line		0x11
	Int. Pin		0x02
PCI capability
	Caps offset		0x60
	Caps version		1.2
PCI capability
	Caps offset		0x68
PCI capability
	Caps offset		0x78
	Port			0
	Version			2.0
PCI registers
	00	DE 10 EE 0B 06 00 10 00 A1 00 03 04 10 00 80 00
	10	00 C0 97 FE 00 00 00 00 00 00 00 00 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 6E 19 9C 08
	30	00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
	50	00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
	70	00 00 00 00 00 00 00 00 10 00 02 00 A0 8D 00 00
	80	10 28 00 00 01 4D 05 00 0B 01 41 10 00 00 00 00
	100	00 00 00 00 00 00 00 00 00 00 00 00 11 20 06 00
	110	00 20 00 00 00 20 00 00 00 00 00 00 00 00 00 00
	120	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description			Mass storage Controller
Location			bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
	Vendor ID		0x1095
	Model ID		0x3531
	Revision ID		0x01
	PI			0x00
	SubClass		0x80
	BaseClass		0x01
	Cache Line		0x10
	Latency			0x00
	Header			0x00
PCI header
	Address 0 (memory)	0xFEAFFC00
	Address 2 (memory)	0xFEAFC000
	Address 4 (port)	0x0000DC00
	Subvendor ID		0x1462
	Subsystem ID		0x320A
	Int. Line		0x10
	Int. Pin		0x01
PCI capability
	Caps offset		0x54
	Caps version		1.1
PCI capability
	Caps offset		0x5C
PCI capability
	Caps offset		0x70
	Device type		Legacy PCI-E Endpoint Device
	Port			0
	Version			1.0
	Caps class		Advanced Error Reporting
	Caps offset		0x100
PCI registers
	00	95 10 31 35 07 00 10 00 01 00 80 01 10 00 00 00
	10	04 FC AF FE 00 00 00 00 04 C0 AF FE 00 00 00 00
	20	01 DC 00 00 00 00 00 00 00 00 00 00 62 14 0A 32
	30	00 00 00 00 54 00 00 00 00 00 00 00 10 01 00 00
	50	00 00 00 00 01 5C 22 06 00 20 00 08 05 70 80 00
	70	10 00 11 00 03 F0 00 00 00 30 09 00 11 F4 03 00
	80	00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
	100	01 00 01 00 00 00 00 00 00 00 00 00 31 20 06 00
	110	00 20 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
Description			OHCI FireWire Controller
Location			bus 4 (0x04), device 9 (0x09), function 0 (0x00)
Common header
	Vendor ID		0x1106
	Model ID		0x3044
	Revision ID		0xC0
	PI			0x10
	SubClass		0x00
	BaseClass		0x0C
	Cache Line		0x10
	Latency			0x40
	Header			0x00
PCI header
	Address 0 (memory)	0xFEBFF800
	Address 1 (port)	0x0000EC00
	Subvendor ID		0x1462
	Subsystem ID		0x350D
	Int. Line		0x11
	Int. Pin		0x01
PCI capability
	Caps offset		0x50
	Caps version		1.1
PCI registers
	00	06 11 44 30 07 00 10 02 C0 10 00 0C 10 40 00 00
	10	00 F8 BF FE 01 EC 00 00 00 00 00 00 00 00 00 00
	20	00 00 00 00 00 00 00 00 00 00 00 00 62 14 0D 35
	30	00 00 00 00 50 00 00 00 00 00 00 00 11 01 00 20
	50	01 00 02 E4 00 00 00 00 00 00 00 00 62 14 00 03
DMI
DMI BIOS
	vendor			American Megatrends Inc.
	version			V1.5
	date			10/13/2007
DMI System Information
	manufacturer		MSI
	product			MS-7350
	version			1.0
	serial			To Be Filled By O.E.M.
	UUID			{FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
DMI Baseboard
	vendor			MSI
	model			MS-7350
	revision		1.0
	serial			To be filled by O.E.M.
DMI System Enclosure
	manufacturer		To Be Filled By O.E.M.
	chassis type		Desktop
	chassis serial		To Be Filled By O.E.M.
DMI Processor
	manufacturer		Intel
	model			Intel(R) Core(TM)2 Quad CPU    Q6700  @ 2.66GHz
	clock speed		3330.0 MHz
	FSB speed		267.0 MHz
	multiplier		12.5x
DMI Memory Controller
	correction		64-bit ECC
	Max module size		1024 MBytes
DMI Memory Module
	designation		DIMM1
	size			1024 MBytes (double bank)
DMI Memory Module
	designation		DIMM3
DMI Memory Module
	designation		DIMM2
DMI Memory Module
	designation		DIMM4
DMI Port Connector
	designation		J1A1 (internal)
	designation		PS2Mouse (external)
	port type		Mouse Port
	connector		PS/2
DMI Port Connector
	designation		Keyboard (external)
	port type		Keyboard Port
	connector		PS/2
DMI Port Connector
	designation		J2A2 (internal)
	designation		USB1 (external)
	port type		USB
	connector		Access Bus (USB)
DMI Port Connector
	designation		USB2 (external)
	port type		USB
DMI Port Connector
	designation		J4A1 (internal)
	designation		LPT 1 (external)
	port type		Parallel Port ECP/EPP
	connector		DB-25 male
DMI Port Connector
	designation		J2A1 (internal)
	designation		COM A (external)
	port type		Serial Port 16550A
	connector		DB-9 male
DMI Port Connector
	designation		J6A1 (internal)
	designation		Audio Mic In (external)
	port type		Audio Port
	connector		Mini Jack (headphones)
DMI Port Connector
	designation		Audio Line In (external)
DMI Port Connector
	designation		J6B1 - AUX IN (internal)
	connector		On Board Sound Input From CD-ROM
DMI Port Connector
	designation		J6B2 - CDIN (internal)
DMI Port Connector
	designation		J6J2 - PRI IDE (internal)
	connector		On Board IDE
DMI Port Connector
	designation		J6J1 - SEC IDE (internal)
DMI Port Connector
	designation		J4J1 - FLOPPY (internal)
	connector		On Board Floppy
DMI Port Connector
	designation		J9H1 - FRONT PNL (internal)
	connector		9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
	designation		J1B1 - CHASSIS REAR FAN (internal)
DMI Port Connector
	designation		J2F1 - CPU FAN (internal)
DMI Port Connector
	designation		J8B4 - FRONT FAN (internal)
DMI Port Connector
	designation		J9G2 - FNT USB (internal)
DMI Port Connector
	designation		J6C3 - FP AUD (internal)
DMI Port Connector
	designation		J9G1 - CONFIG (internal)
DMI Port Connector
	designation		J8C1 - SCSI LED (internal)
DMI Port Connector
	designation		J9J2 - INTRUDER (internal)
DMI Port Connector
	designation		J9G4 - ITP (internal)
DMI Port Connector
	designation		J2H1 - MAIN POWER (internal)
DMI Extension Slot
	designation		AGP
	type			AGP 4x
	width			32 bits
	populated		yes
DMI Extension Slot
	designation		PCI1
	type			PCI
	width			32 bits
	populated		no
DMI OEM Strings
	string[0]		To Be Filled By O.E.M.
DMI Physical Memory Array
	location		Motherboard
	usage			System Memory
	correction		None
	max capacity		16384 MBytes
	max# of devices		4
DMI Memory Device
	designation		DIMM1
	format			DIMM
	type			SDRAM
	total width		64 bits
	data width		64 bits
	size			1024 MBytes
DMI Memory Device
	designation		DIMM3
	format			DIMM
	type			SDRAM
	total width		64 bits
	data width		64 bits
	size			1024 MBytes
DMI Memory Device
	designation		DIMM2
	format			DIMM
	type			SDRAM
	total width		64 bits
	data width		64 bits
	size			1024 MBytes
DMI Memory Device
	designation		DIMM4
	format			DIMM
	type			SDRAM
	total width		64 bits
	data width		64 bits
	size			1024 MBytes
Graphics
Number of adapters		1
Graphic APIs
API				NVIDIA I/O
API				NVIDIA NVAPI
Display Adapters
Display adapter 0
	Name			NVIDIA GeForce GTX 550 Ti
	Revision		A1
	Memory size		1024 MB
	PCI device		bus 1 (0x1), device 0 (0x0), function 0 (0x0)
	Vendor ID		0x10DE (0x196E)
	Model ID		0x1244 (0x089C)
	Performance Level	Default
		Core clock	50.5 MHz
		Shader clock	101.0 MHz
		Memory clock	135.0 MHz
	Performance Level	2D Desktop
		Core clock	405.0 MHz
		Shader clock	810.0 MHz
		Memory clock	324.0 MHz
	Performance Level	3D Applications
		Core clock	900.0 MHz
		Shader clock	1800.0 MHz
		Memory clock	2052.0 MHz
Software
Windows Version			Microsoft Windows 7 (6.1) Ultimate Edition   (Build 7600)
DirectX Version			11.0
ACPI
ACPI Tree
_GPE
  _L01
  _L0B
  _L10
  _L09
  _L0D
  _L05
  _L00
  _L15
  _L07
  _L11
_PR_
  CPU1
    STBL
    NCPU
    TYPE
    HNDL
    CFGD
    TBLD
    _PDC
    _OSC
  CPU2
    STBL
    NCPU
    TYPE
    HNDL
    CFGD
    TBLD
    _PDC
    _OSC
  CPU3
    STBL
    NCPU
    TYPE
    HNDL
    CFGD
    TBLD
    _PDC
    _OSC
  CPU4
    STBL
    NCPU
    TYPE
    HNDL
    CFGD
    TBLD
    _PDC
    _OSC
_SB_
  PR00
  AR00
  PR01
  AR01
  PR08
  AR08
  PR0A
  AR0A
  PR0B
  AR0B
  PR0C
  AR0C
  PRSA
  PRSB
  PRSC
  PRSD
  RSEA
  RSEB
  RSEC
  RSED
  RSMB
  RSB2
  RSMU
  RSA1
  RSA0
  RSB0
  RSAC
  RSZA
  RSCI
  RSC9
  RSTA
  RSIR
  RSII
  PCI0
    _HID
    _ADR
    _BBN
    _UID
    _PRT
    NPTS
    NWAK
    SBRG
      _ADR
      SPTS
      SWAK
      SMIE
      PS1S
      PS1E
      SXCT
      S1CT
      S3CT
      S4CT
      S5CT
      PIMC
      PIRA
      PIRB
      PIRC
      PIRD
      PREA
      PREB
      PREC
      PRED
      PIRM
      PIU2
      PMUD
      SIID
      PIID
      PIU0
      PIU1
      PILN
      PAZA
      PAUI
      PIMO
      PR0E
      PIC_
        _HID
        _CRS
      DMAD
        _HID
        _CRS
      TMR_
        _HID
        _CRS
      RTC0
        _HID
        _CRS
      SPKR
        _HID
        _CRS
      COPR
        _HID
        _CRS
      UAR1
        _UID
        _HID
        _STA
        _DIS
        _CRS
        _SRS
        _PRS
        CMPR
      UAR2
        _UID
        _HID
        _STA
        _DIS
        _CRS
        _SRS
        _PRS
        CMPR
      FDC_
        _HID
        _FDE
        _STA
        _DIS
        _CRS
        _SRS
        _PRS
      LPTE
        _HID
        _STA
        _DIS
        _CRS
        _SRS
        _PRS
        LPPR
        EPPR
      RMSC
        _HID
        _UID
        CRS_
        _CRS
      HPET
        _HID
        _UID
        CRS_
        _STA
        _CRS
        HPTE
        NVID
      LPDC
      S3F8
      S2F8
      S2E8
      S3E8
      M300
      M330
      FDC0
      P378
      P278
      P3BC
      G200
      G208
      RRIO
      RDMA
      OMSC
        _HID
        _UID
        CRS_
        _CRS
      PS2K
        _HID
        _CID
        _STA
        _CRS
        _PRW
        _PSW
      PS2M
        _HID
        _CID
        _STA
        M2R0
        M2R1
        _CRS
        _PRW
        _PSW
      SIOR
        _HID
        _UID
        CRS_
        _CRS
      DCAT
      ENFG
      EXFG
      LPTM
      UHID
      KBFG
      MSFG
      U1FG
      U2FG
      SIOS
      SIOW
      SIOH
      IOID
      INDX
      DATA
      LDN_
      FDCP
      LPTP
      URAP
      URBP
      ACTR
      IOAH
      IOAL
      IOH2
      IOL2
      INTR
      DMCH
      CRE0
      CRE1
      CRE2
      CRE3
      CRE4
      OPT0
      OPT1
      OPT2
      OPT3
      OPT4
      OPT5
      CGLD
      DSTA
      DCNT
      CRS1
      IRQM
      DMAM
      IO11
      IO12
      LEN1
      CRS2
      IRQE
      DMAE
      IO21
      IO22
      LEN2
      IO31
      IO32
      LEN3
      DCRS
      DSRS
    _S3D
    _S1D
    NATA
    NVRB
      _HID
      FNVR
      _DIS
      _SRS
      _STA
      _CRS
    PCIE
      _HID
      _UID
      CRS_
      _CRS
    NSMB
      _ADR
      _PRW
    USB0
      _ADR
      _S1D
      _S3D
      _PRW
    USB2
      _ADR
      _S1D
      _S3D
      _PRW
    NMAC
      _ADR
      _PRW
    IDE0
      _ADR
      PTS0
      SID0
      SID1
      SID2
      SID3
      SID4
      SID5
      IRQM
      IR0M
      REGF
      _REG
      A090
      ID20
      IDTS
      IDTP
      ID22
      UMSS
      UMSP
      TIM0
      TMD0
      PIO0
      DMA0
      PIO1
      DMA1
      CHNF
      CFG2
      SSPT
      SMPT
      PSPT
      PMPT
      SSAS
      SMAS
      PSAS
      PMAS
      SDDR
      SDDA
      PDDR
      PDDA
      SSUT
      SSUE
      SMUT
      SMUE
      PSUT
      PSUE
      PMUT
      PMUE
      GMPT
      GMUE
      GMUT
      GSPT
      GSUE
      GSUT
      CHN0
        _ADR
        _GTM
        _STM
        DRV0
          _ADR
          _GTF
        DRV1
          _ADR
          _GTF
      CHN1
        _ADR
        _GTM
        _STM
        DRV0
          _ADR
          _GTF
        DRV1
          _ADR
          _GTF
      DRMP
      GTM_
      STM_
      AT01
      AT02
      AT03
      AT04
      ATA0
      ATA1
      ATA2
      ATA3
      ATAB
      CMDC
      GTFB
      GTF_
      RATA
    ATA0
      _ADR
      PRI0
        _ADR
        SPTM
        _GTM
        _STM
        MAST
          _ADR
          _GTF
      SEC0
        _ADR
        SSTM
        _GTM
        _STM
        MAST
          _ADR
          _GTF
      DRMP
    ATA1
      _ADR
      PRI0
        _ADR
        SPTM
        _GTM
        _STM
        MAST
          _ADR
          _GTF
      SEC0
        _ADR
        SSTM
        _GTM
        _STM
        MAST
          _ADR
          _GTF
      DRMP
    P0P1
      _ADR
      _PRW
      _PRT
    HDAC
      _ADR
      _PRW
    MC97
      _ADR
      _PRW
    P0P8
      _ADR
      _PRT
    P0PA
      _ADR
      _PRT
    P0PB
      _ADR
      _PRT
    P0PC
      _ADR
      _PRW
      _PRT
    CRS_
    MIN5
    MAX5
    LEN5
    MIN6
    MAX6
    LEN6
    _CRS
  BN00
  SMIP
  LCTM
  LCNM
  SLPS
  SLPB
    _HID
    _STA
    SBEV
    _PRW
  RMEM
    _HID
    _UID
    CRS_
    _CRS
  PWRB
    _HID
    _UID
    _STA
  BUFA
  ICRS
  LSTA
  LPRS
  LCRS
  LCRO
  LSRS
  LSRO
  LNKA
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNKB
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNKC
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNKD
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNEA
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNEB
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNEC
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LNED
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LUB0
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LUB2
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LMAC
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LAZA
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LACI
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LMC9
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LSMB
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LPMU
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LSA0
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LSA1
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  LATA
    _HID
    _UID
    _STA
    _PRS
    _DIS
    _CRS
    _SRS
  XCPD
  XNPT
  XCAP
  XDCP
  XDCT
  XDST
  XLCP
  XLCT
  XLST
  XSCP
  XSCT
  XSST
  XRCT
  MUTE
  RBPE
  RWPE
  RDPE
  WBPE
  WWPE
  WDPE
  RWDP
  RPME
_SI_
_TZ_
_REV
_OS_
_OSI
_GL_
DP80
DP90
SPIO
IOHB
IOHL
IOVB
IOVL
SSMI
SSEP
SSEN
APIC
SHPB
SHPL
PMBS
PMLN
SCBS
SCLN
ACBS
ACLN
IGPB
IGLN
ACA4
SCIO
SCTL
EXTS
PCIB
PCIL
WKTP
NSLB
BIOS
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
MG1B
MG1L
MG2B
MG2L
DMAX
HPTA
CPB0
CPB1
CPB2
CPB3
ASSB
AOTB
AAXB
SMIF
DTSE
DTS1
DTS2
MPEN
TPMF
RRIO
RDMA
PICM
_PIC
OSVR
OSFL
MCTH
PRWP
GPRW
WAKP
DEB0
DBG8
DEB1
DBG9
SCPP
APA4
FZTF
WOTB
WSSB
WAXB
_PTS
_WAK
_S0_
_S1_
_S4_
_S5_
PTS_
WAK_
Way way too much disorganized information to try and scroll thru to pick out the information we need to try and help. Most peeps use what is outlined below to be more visibly informative.
Using screen capture software capture the CPU-z image at the CPU button; the Memory button and the SPD button. The buttons are across the top of the CPU-z window. The Mainboard button can also be used and will show the bios version in case one wanted to check the motherboard bios being up to date.
NOTE: I never capture the whole monitor but only the CPU-z window at each button so that the dang image is
not so...so ginormous.
This is link to HWmonitor and as shown on the screen; you would also check the cpu plus (+) so that the core temps of the cpu would be shown. AMD certainly needs to see the core temps at least the later AMD cpus.
Download site for Prime95 with some "how to's" included. Prime 95 can be used to stress a system and with HWMonitor opened a temp log will be kept to see if temps get out of hand during or at the time of a failure of P95, if such does occur because of an unstable configuration.
Okay I have not been looking for a screen capture tool but wish many would use some with window capture instead of the whole screen. This proggie comes highly recommended. 4 Capture Modes: Window, Region, Scrolling and Full Screen. I normally use Window or Region so the whole dang screen is not captured and makes the image so dang large. I save capture to .jpg so files are smaller in general.
