- Jan 21, 2013
Currently trying to figure out how I want to place fans in my NZXT H440, what I mean by this is simple intake/exhaust. I was under the assumption that you use SP fans for radiators, which is what I use them for currently. Currently all I have setup is a Corsair H115i set up as a front mounted radiator with the two stock fans set as intake. I am thinking that I want a 140mm exhaust fan on the rear panel of the case but other than that I am just lost.
Have also heard that the H440 has a very "restricted top fan vent" and that it would be best to use SP intake fans here, but I don't know if this is warranted.
Anyways, just looking for some simple suggestions (I don't need to know how to calculate CFM etc). Current setup = front mounted radiator with two SP intakes, that's it. Brand new build if you're wondering. Thanks in advance
