- Jan 16, 2011
- Deep South
I bought this fan controller from newegg because it was shiny and I wanted to add some bling to my new rig. Oh and it would allow me to control my fans too... that is, if it wasn't such a big piece of garbage. Shiny garbage, but garbage none the less. It even had some attractive temperature sensors, but they could not make up for this sorry excuse of a fan controller. It even has a nice digital clock which works great so long as I don't inadvertently press the reset button which I believe was tactically placed to cause maximum inconvenience and grief.
So I took it out of the box and set about installing it. It looked very nice, and shiny, and promising, but my optimism would soon be defeated by this incompetent electronic abomination. It was easy enough to install, encouraging me of its worth and function. The shiny display came to life when I powered on the computer, and I was pleased with its great aesthetic appeal. But it was all just camouflage for the inferior design of the Sentry LX. Not long after I had booted into Windows, an infernal howl began emanating from the Sentry LX in short, persistent beeps. They were weak, pathetic cries for attention, which I found to be unwarranted as the temperatures were all normal, and the fans were running.
Further research into this malady revealed that the 230mm top fan of the case probably required too much power of the fan controller. Preposterous! It seems that when I switch the mode from automatic to manual that the beeping stops, but I don't think the controller even sets the fans as high as they will spin! Also, I can't connect my cpu fan to it because it only supports 3 pin connectors.
Perhaps this is all my fault for not researching it further before purchasing, but this fan controller has been a great disappointment and I will be returning it immediately. 0/10 would not buy again.
If anyone can recommend a better (and shiny) fan controller, please be my guest. This one looks nice (and shiny).
TL;DR: NZXT Sentry LX is shiny, but it sucks huge [redacted]. Don't buy it!!!
