I thought I'd play around with the timings this time around. Quite a long time ago with this PC I played around with the CPU and the DRAM frequency and settled back to using stock speeds on both for the duration I've had this PC. For some reason this RAM would never go above the 2400 unless there was something I missed aside from upping the RAM voltage. The settings caps out at 1.8v for RAM. Anyway my results so far for timings: 9-10-12-30 1T (2400) at 1.75v. stock timings are 10-12-12-31 1T at 1.65v. If I change to 8-10-12-31 1T memtest86+ will generate errors beginning at test #8. If I change to 9-9-12-31 1T or 9-10-11-31 1T memtest86+ generates errors within the first few tests. I haven't tried changing the 4th timing number yet and the dozen more settings in DRAM timings section of the settings. I pretty much just use this PC for gaming. And performance wise without O/C anything seems fine so with tweaking stuff I don't know if I can expect any change in the gaming experience. If whatever can be achieved does have an impact on the gaming experience then I'll keep the settings. I know on my previous PC the CPU was significantly different and had an impact on gaming and I don't remember messing with the RAM because it wasn't like this RAM with passive cooling. Thoughts?
