- Jan 6, 2005
- Buffalo NY
Running 2k w/sp4 and a HP LC2600N LCD TV/monitor using a DVI cable input, Windows identifies the monitor only as a Plug & Play. In XP it correctly identifies the monitor as a HP LC2600.
So I understand it correctly, when Windows IDs' the monitor with the correct name through the EDID data, it then creates a inf file? If so, can that file be used elsewhere (on another computer and O/S) ?
Without getting into a 2k vs FP here since I don't want to change O/S's just for this, can I get that file and use it on my 2k box in the hopes that it will keep the monitor happy?
What is happening and the problem; because the computer and monitor aren't 'talking' properly, some functions in the monitor aren't available. Namely the ability to set the monitor to the native resolution of 1366x768 and a 'Dot by Dot' aspect setting.
It's been reported that 1:1 pixel mapping is possible with a XP box and a DVI input.
Hope that made sense.................
Thanks in advance.
Thanks in advance.
