- Dec 13, 2005
hey guys can you check this out and give me so pointers/advice on pushing it faster its a locked 2500+ with a sp-97/ tornado in a antec 1080 soho case with all grills cut
current temps idle cpu 34c
MB temp 18 c
v-core 1.728
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Barton
Specification AMD Athlon(tm) XP 3200+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 2205.1 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 200.5 MHz
Bus Speed 400.9 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2205.1 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A7N8X-E, REV 2.xx
BIOS vendor Phoenix Technologies, LTD
BIOS revision ASUS A7N8X-E Deluxe ACPI BIOS Rev 1013
BIOS release date 11/12/2004
Chipset nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP-T rev. A4
Sensor chip Asus ASB100
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 200.5 MHz
FSBRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC3200 - 256 MBytes
Module 1 Corsair DDR-SDRAM PC3200 - 256 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
thanks a bunch
MB temp 18 c
v-core 1.728
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Barton
Package Socket A
Technology 0.13 µ
Bus Speed 400.9 MHz
L2 Location On Chip
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
FSBRAM 1:1
Software
thanks a bunch
