- May 22, 2011
- USA
I have read the stickies on Overclocking for Bloomfields. I made a thread a while back and was thinking to start a fresh new thread as my last post I wanted to work with a 3rd party OC utility but from what I was told I was better off going through the Bios. So I decided to start fresh and forget the 3rd party utility.
My cpu is a i7-950 on a Asus Sabertooth X58 with Corsair XMS3 1333 mhz 6gigs (7-7-7-20 1.65v; TR3X6G1333C7). My cpu cooling is H20.
I then went into the bios and made these changes:
CPU Freq: 4002 mhz
Dram Freq: 1047 mhz
OC: Manual
Ratio: 23
Speedstep: Disabled
BCLK Freq: 174
PCIE Freq: 100
DRAM Freq: 1047 mhz
UCLK Freq: 2093
QPI Link Data rate: Auto
CPU Volt: 1.31250
CPU PLL: Auto
QPI/Dram Core: 1.35
IOH Volt: 1.18
IOH PCIE Volt: Auto
ICH Volt: Auto
ICH PCIE Volt: Auto
Dram Bus Volt: Auto
...... the rest is auto etc
I had the vcore @ 1.30 and booted up fine. Ran Prime and hit a BSOD (0x0000003b). So I did some research and was told to most likely up the cpu voltage. I bumped the cpu volt. to 1.31250 and after running prime 95 for a few mins during its cooldown from 100%, at 90% I than get a BSOD (0x000000fc). I than went back to default. I use BlueScreenView so if anyone wants to see the dump files, let me know. Thanks.
CPU Freq: 4002 mhz
Dram Freq: 1047 mhz
OC: Manual
Ratio: 23
Speedstep: Disabled
BCLK Freq: 174
PCIE Freq: 100
DRAM Freq: 1047 mhz
UCLK Freq: 2093
CPU Volt: 1.31250
CPU PLL: Auto
QPI/Dram Core: 1.35
IOH Volt: 1.18
IOH PCIE Volt: Auto
ICH Volt: Auto
ICH PCIE Volt: Auto
Dram Bus Volt: Auto
