- Sep 7, 2008
Hi! I need a hand with my system because I search on internet for good OC settings.
AMD 3700+ Clawhammer 2.4 GHZ 1 MB
2x 1 GB Kinston DDR 400
DFI LAN Party NFS 250 GB nForce 3
BFG nVida 7600 GS OC
I want to achive 2.8 or 3 GHZ, I found this little guide lines arround, tell me what do you think
CPU frequency: 2706 mhz (246x11)
CPU voltage: 1.52
Temperature: 30 C
Cooling: Corsair HC200
Motherboard: DFI 250GB UT3
Memory: 2x512 XMS3500
Memory bus frequency: 246
Memory timing: 2-2-2-10 (I need to know the order,like tRSD etc...)
Memory voltage: 3.1
HT frequency: 3x
CPU frequency: 3000Mhz (250x12)
CPU voltage: 1.76
Motherboard: DFI UT
Memory: Mushkin PC3500 LII
Memory frequency: 250Mhz 1:1
Memory timing: 2-2-2-5 1T (I need to know the order,like tRSD etc...)
Memory voltage: 3.5v
HT frequency: x2.5
Basically I have a Zalman Reserator so overheat is not a problem for me, but I dont have any RAM disipators should I?
Regarding the 3 GHZ achievement I will harm too much my processor?
Thanks a lot for your help!!! =)
CPU voltage: 1.52
Temperature: 30 C
Memory voltage: 3.1
HT frequency: 3x
CPU voltage: 1.76
Motherboard: DFI UT
HT frequency: x2.5
