Code 4 said:
I am running a half multi. CPUZ and Clockgen both show my RAM running at 266mzh. Is that not correct? I have great bandwidth at my current settings. Sandra is around 7300. I can not run the 9X multi at any speeds and my chip only has about 150mhz worth of an OC in it. So I am pretty limited on my other multiplier clocks.
im afraid so i was going to point out the same thing. CPU-Z, Clockgen, memtest and almost everyother Prog shows ram speeds wrong on A64
your ram is at "9.5 / 10" ratio when your using 9.5cpu multi
9.5x266htt=2527mhz (and if ram is at 1:1 in bios) your ram is at 252.7mhz.
you can test and see but 10x252.7htt (w/ 1:1 in bios) will almost undoubtedly give you exacly the same results.
a64 can be very misleading..
so your ram is only at 252.7mhz
im sorry to inform you..
with a64, if you wish you ram to run at 1:1 there must be 3 things in place..
1. this is the obvious one, your ram must be set to 1:1(200mhz) in bios
2. you MAY NOT use half cpu multi(just incase your wondering half LDT multies are ok)
3. you MAY NOT use 4x cpu multi, because this will put your ram at 4:5..
-Jess-
