Joe your preaching to the pasty faced choir now
Via long-term testing running my
Q6600 at
9x334FSB (1.28V) = 128W ~
9x420FSB (1.450V) = 205W I have emprically verifed your statement (at least I hope to show this in my upcoming addendum to my
Spreading it Thin TIM Round-up.
I discovered
thermal compounds such as IC-7, with higher conductivity / higher viscosity as compared to the recent
rapid curing pastes, can be summarized in those Lite Beer commercials of 1970's. The exception being the panegyrical salutations today claim: "
More fillers - less particles" (conductive particles).
Products like Tuniq TX-2 seem to rely more heavily on the catalyst which essentially transports the thermal particles to the gaps and striations. This aspect of the compound is also known as the vehicle or filler. These pastes seem great because they show their potential immediately as they are less viscuous with rapidly "evaporating" fillers (to use a poor description for what is essentially curing).
I tested TX-2 for a month and for the last month IC-7 on a D-Tek WB with a Q6600, basically overclocking this chip as high as 3.78GHz. I have been trying to reach the 4GHz plateau. In order to expidite cure time I have been doing two things, first I've been checking and tensioning the mounting springs and increased tension to the point the springs are almost maxed out. The second method which I have found improves the curing process needs a little introduction.
It was some years ago I befriended Nevin House of Arctic Silver whom taught me alot about thermodynamics. When AS5 came out he suggested after a week or so of testing, grabbing hold of your HSF and rotating the block on the processor just a few mm's would expedite the curing process. Obviously this can only be done very carefully and your only going to be able to "rotate" the heatsink on the paste and CPU IHS so much.
I tried this with AS3 and AS5 and the results were that AS3 not only out-performed AS5 it lasted much longer. Nevin claimed AS5 improved with time, I found this was true after follwing his instructions but only for about 60-days. With AS3 however, the effects of rotating or rather shifting the heatsink improved the curing time and that AS3 did perform better over a longer period of time.
I am now finding this to be true with IC-7. I find IC-7 is a paste to which the expression: "
Less fillers - more particles" applies. And for these reasons, just as you stated pressure and an even increased pressure as the paste cures in the first, say 48-hour break-in period, is even more important.
Since I didn't have IC-7 in time for my Round-up the addendum or extended Round-up will dicuss viscosity and application. I will reiterate how important these factors are, especially the all important element of Time...
