Hi All,
Been out of the WC'ing scene for a number of years. Had a heater core rig running for a number of years, and currently still running a Gigabyte Mercury 3D AIO WC Case on my Thuban X6. I know its a poor excuse, however for a giant tower aluminum case with basic WC, it was a steal at NewEgg BF for $90 in 2008.
For some reason, I've decided I want to try running case-less.
Initial draft system is going to be 2' x 2.5' plywood mounted to the wall behind my SOHO desk multi-monitor set-up.
Current heat load is moderate with the Thuban X6 OC 2.8/3.6 and stock 7870. However, I do envision an 8350 with a better OC and perhaps an R9 in the near future depending upon how the WC shapes up. This would be a work and moderate gaming system, not on 24/7.
Because I am not limited by case size, I was hoping to be able to get either a couple of heater cores or small bike radiators, and be able to avoid having a ton of fans by having excess rad capacity.
Actually, this may be insane or just plain ignorance, however I could see something like this :http://www.ebay.com/itm/N23215310A-...Tank-Mazda-RX-7-85-84-1985-1984-/190939478737
Final build is going to be 1/2" or greater lexan, with matching covers/hood/shroud. Getting a tinted cover would remove any eyesoreness I think.
I'm wondering if an Eheim 1046/48 would work?
Anyways, appreciate any fedback.
Since I've outgrown the need for LEDs and UV shiny, on the surface a $60-70 rad like this, and a 60-70 pump plus some tubing seems like a no brainer. Assuming this type of rad doesn't require massive head.
