RDWest2005 said:i use all fuel line worm clamps
i only have the plastic clamps on pump
but i just PM a guy about how to clean up the mess now - i think its left a slick feeling film over it all
i don't know whether to soak the whole board under alchahol and card then blow them off with air compressor and let dry or what
~RD
Oh I see what you mean, you didn't tighten the plastic barbs tight enough, I thought you said the plastic clamps weren't tight enough. I know what you mean about stripping the plastic barbs though, I tightened mine down until they couldn't tighten anymore, but I was sure afraid that it would break the plastic or strip the threads. I can certainly understand your fear of tightening them tighter. They are strong though and I think it would take someone seriously trying to break or strip them to do so.
