- Mar 30, 2012
pretty simple question, which would make my computer cooler:
230 x 30 mm standard fan x 1, 700 RPM, 110 CFM, 19 dBA (support 120 x 25 fan x 4)
The Coolermaster haf 932 says it supports 4x 120 x 25 mm fans on the side panel. will that make it run cooler than the one big 230 x 30 mm fan? Thanks for your help.
