I ran out of all ideas i tried everything, basically even the wireless thing shows i have internet (sometimes no internet) but my signal strength is always 100%. my ps3, wii, and 2 other computers run perfectly fine on the net.
I had enough so i even ended up REFORMATTING my hard drive... expecting this to fix the problem... but for whatever reason it didnt.
i even switched out my NIC card to another pci slot... this time the network card was found instantly and windows installed it (after reformat windows 7 didnt recognize it)
i am gonna post my ipconfig and i noticed it shows network adapter #2 (is that anything significant? i never seen that before)
also notice my ping to my router.
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Josh>ping 192.168.1.5
Pinging 192.168.1.5 with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 192.168.1.5: bytes=32 time<1ms TTL=64
Request timed out.
Ping statistics for 192.168.1.5:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\Josh>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Josh-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : wi.rr.com
Wireless LAN adapter Wireless Network Connection
2:
Connection-specific DNS Suffix . : wi.rr.com
Description . . . . . . . . . . . : Linksys Wireless-G PCI Adapter #2
Physical Address. . . . . . . . . : 00-25-9C-A5-73-47
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::4164:ca3:855a:e715%21(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, February 16, 2010 10:44:34 AM
Lease Expires . . . . . . . . . . : Wednesday, February 17, 2010 10:59:39 AM
Default Gateway . . . . . . . . . : 192.168.1.5
DHCP Server
. . . . . . . . . . . : 192.168.1.5
DHCPv6 IAID . . . . . . . . . . . : 352331164
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-0C-94-52-6C-F0-49-54-9E-4C
DNS Servers . . . . . . . . . . . : 209.18.47.61
209.18.47.62
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E
Gigabit Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : 6C-F0-49-54-9E-4C
Tunnel adapter isatap.{1C15EB15-4762-4785-B405-0D6631476EB6}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.wi.rr.com:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e74:2cca:261c:b77f:97bd(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2cca:261c:b77f:97bd%14(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\Josh>
Request timed out.
Request timed out.
Request timed out.
2:
DHCP Server
209.18.47.62
erred)
C:\Users\Josh>
