- Oct 22, 2013
Hi all,
So I had a 3-way SLI set up on those gtx480's and yesterday I came into my office with the computer off. That's weird I thought... maybe a temporary power outage at night?
I leave my computer running 24/7 all the time. I run BOINC at night with Einstein@home running using the CPU and 3 GPU's separately. Had this running for over a year now. No problems.
Anyways, I go to turn the computer back on, I start smelling something burning, turn it off right away and go on to investigate. I'm thinking PSU and off I go setting up an RMA with Antec (I have the 1200W PSU). Took everything apart though to make sure, tested the PSU, hmm, works fine under load. I then start testing the GPU's separately. Low and behold one of them is dead. Took it apart and one of the voltage regulators is fried to a crisp.
Ordered a bunch of them from china and now have to wait to replace it, we'll see if that's the only thing that fried.
So my question is this because it's been bugging me for a while. If you have a SLI or a triple SLI setup, is it better to have the cards with reference design of the fan? (one fan blowing air out through the back) or one of those other 2 or 3 fan designs that just blow air everywhere in the case? My case is the Rosewill one Link, 2 fans in the front, one on the side blowing air in then one in the back and one on top blowing air out.
It seems to me that if I only have one card, it's ok to buy one of those non-reference fan design cards, but if running in SLI or 3-way SLI, the reference design would be superior?
