- Jul 1, 2001
ADA3000DAA4BW
LBBWE 0548TPCW
Just finished upgrading from a AXP-M 2.4GHz system to DFI nF4-D and Venice 3000+ E6. I was expecting 2.7GHz out of this Venice but somehow I hit a wall at 2.5GHz. Wish I had waited for an Opteron.
Right now, my 3000+ is prime stable at 2.4GHz 9x267 at 1.5V as set in BIOS (software says 1.44-1.46V).
I've already loosened RAM timings to 3-4-4-8 2T and running on the lowest divider to factor out the RAM issue. HTT ratio is set at 3x and have bumped the LDT and chipset voltage to 1.3V and 1.6V respectively.
Temps seem to be fine, small fft with SP2004 is about 45C/47C/38C (CPU/PWMIC/chipset).
At 2.5GHz (9x278), I've tried all the voltages from 1.5V up to 1.55V in BIOS but will still fail Prime95, temps are still below 47C. I was told that I should not exceed 1.55V~1.6V with the Vcore and since I was still on stock cooling, I haven't tried higher voltages.
What seems to be the limiting factor? I see that most Venice will do 2.4GHz right out of the box with default Vcore and most are clocking at 2.8GHz easily on air.
