Hey fellas,
Im converting over to a custom watercooling loop as air is just not cutting it enough!
Just want your opinion on these things im going to purchase and if there decent for what im going to cool.
Im planning to get a 2x120mm rad at the top, then a 1x120 rad for the rear of the case which will be going to cool my CPU -> 1st GPU -> 2nd GPU.
Heres the list
Waterblocks:
Koolance CPU-370 CPU Waterblock
EK Full Cover VGA Block EK-FC570 GTX SE Acetal+EN Nickel
Radiators:
Koolance Copper Core CU1402V High Flow 2x140mm Radiator
Koolance Copper Core CU420V High Flow 1x120mm Radiator
Pump:
Bitspower D5/MCP655 Pump Mod Kit Matte Black
Resevior:
XSPC Laing DDC BayRes One
Fittings and Tubing:
Bitspower G1/4 Matte Black 3/8 Fitting
Koolance Hose Clamp for OD 19mm (3/4in)
Koolance Tubing 3/8, Clear UV-Reactive
Obviously most of it is Koolance, as I have read that they are very good.
Heres the list
Waterblocks:
Radiators:
Pump:
Resevior:
