AH64Driver
- Apr 7, 2021
This is my first AMD build, and I’m still learning about the hobby so bear with me.
AMD Ryzen 7 5800x
AMD Wraith Cooler
Asrock B550M AC
EVGA RTX 2080 Super
2x8 GB DDR4 (3600 mghz)
EVGA 750 watt PS
I’m having some trouble with my setup, at stock BIOS settings (3800 MGHZ, 1.10v) will run Modern Warfare (I play other titles as well, but I wanted to try OC because the game is CPU intensive) fine, but I’m only seeing about 70 (albeit stable) FPS in game. I was under the impression that this build would perform past that mark without OC. Is this normal? Additionally, when I try to OC, I see nominal, almost non-existent increases in game performance. Went all the way up to 4500 mghz (max CPU clock speed, and 1.4v). Even turned on XMP and clocked ram to 3200 mghz. Still hovering around 70-80 FPS in game. All drivers are up to date on all HDWR. Any help you might be able to provide is greatly appreciated.
AMD Ryzen 7 5800x
AMD Wraith Cooler
Asrock B550M AC
EVGA RTX 2080 Super
EVGA 750 watt PS
