- Jul 1, 2008
- Binghamton, NY
Hi,
This problem happened with the same DIMMs on a different motherboard. I think the problem is most likely signal integrity but possibly Vdd fluctuations causing memory retention errors.
I have a new ECS H87H3-M motherboard, and I've installed four 2GB Crucial 1333MHz DIMMs. I put everything in default configuration, and it works okay until I do something memory-intensive like compiling a Linux kernel. The whole system will lock up, with garbage on the screen and everything.
If I put in one DIMM per channel, it works fine. I have tested all 4 DIMMs this way.
As I had to do with my old MSI board (which was a flaky piece of junk in other ways), I have tried stepping up the DIMM voltage 20mV at a time. As I do that, the failures have become progressively less catastrophic, to the point that now at 1.72V, I've managed to get through one whole kernel compile, but not a second one. (The nominal voltage for these memories is 1.5V.)
Memtest86 ran over night with no errors, so there are no hard failures, although something could be borderline, I guess.
Is it normal to have to boost the voltage to get two DIMMs per channel to work? Is it normal to have to boost it by over 200mV? What are the expectations here?
Also, since I've had to increase the voltage for another motherboard, and the RAMs work fine with one per channel, does this probably rule out the new motherboard and CPU? (I'd have to try other DIMMs two per channel to be totally sure, but I'm trying to work out the likeliest causes.)
Thanks!
Thanks!
