flamerail
Disabled
- May 5, 2005
If you was to overvolt the hd motor and make it run faster thing the head could keep up if you only whent up like 500 rpm more? 7600rpm LMAO
No, but overvolting a processor doesn't make it run faster, overvolting a motor usually does. Still not a good idea. Note however, that HDDs do have a lot of electronics on them that you maybe could overclock with a bit of soldering, but then it may not work (and those really aren't the part that needs to be faster anyway).-maddog- said:Overvolting and overclocking aren't the same thing. Yes you can overclock it if there is a processor in it, the new hybrid ones may have one.
Maviryk said:Not sure what it is on the newer mobos, but on the older ones you can overclock your HD's by increasing the PCI-AGP lock from 33/66 to up to 40/80.
Bad idea though, usually results in data corruptions from the HD not being able to handle that much.
Very nice!demortey@gmail. said:
