- Thread Starter
- #41
If you need more pictures, let me know. Also there is no fan in front of the case since there's no fan slotI am of two minds now. I know the CPU Temp rising so fast is because of the water cooling. No cpu air cooler to cool the socket area which is where CPU Temp comes from.
Is it easy enough to take a good, clear, well-lighted picture of the inside of your case with the side off? I want to see if the H-60 radiator is blocking any air from other fans from getting to the VRM/Socket area.
Edit: I tried running Prime95 bend test with the side case off. I still get 62 Celsius but it just take about 5minutes longer to reach that temperature than with the side panel on
