- Thread Starter
- #61
What make and model case do you have? Are there fans, or at least places to mount fans, in the front or top panel of the case or is the only fan hole at the back?
I can't find the maker or model of the case. The only places it has fans are One slot of the Top(which is the white fan i have, blowing air out the case), One slot of the side(I made a hole myself for the other side fan), And One slot on the back of the case(Where my push/pull fan is)
The front and the other side does not have any fan slots
Multiplier is 19x, set at idle WITH side panel
IDLE Side panel off with a fan blowing directly into the case: 31-32c
With Prime95 bend test running and a fan blowing directly inside the case, i took off the side panel
