- Sep 28, 2003
- University of Michigan
Well, I think JoeC takes that into consideration. If you look at his test bed its pretty nice. It tries to have the same mounting each time.
bigben2k said:
No, what happens is that the throttling valve drops the extra pressure from the bigger pump. All other components behave exactly the same, dropping the pressure according to the flow rate.
nikhsub1 said:
Not if the testing is done properly Caffinehog. Bill uses a 'standard' system typical of most H20 systems? Have you ever seen a picture of his situp? Looks like a mad scientist lab! AFAIK, BillA has the most comprehensive test bench out there for testing water blocks. If the C/W in ANY test is based on anything EXCEPT the block itself, then that test is no good in my book. The goal is to isolate the blocks performance.
I completely agree. That is not at all what you said in your first post though...Caffinehog said:
The point is, Bill tests things with a consistent setup. Other reviewer's setups will vary from this. Therefore, comparing two blocks reviewed by Bill is like comparing apples to apples. Comparing one of Bill's reviews to somebody else's review is comparing apples to oranges.
...but you're missing the point! The pressure drop of a block is a direct result of the flow rate going through it. Nothing else can affect it.Diggrr said:
What exactly is the type of valve used?
I'm using experience with hydraulic and pneumatic machinery, but a normal flow control valve will drop flow rate and pressure only until a second obstruction is met.
Say you had a Swiftec (open design) and a WW (more restrictive).
The flowrate may be set the same on the valve, but the pressure exerted on the water between the valve and the Swifty would be lower than that between the valve and the WW.
That added pressure would be giving the WW an advantage in testing because the higher pressure would increase the flow to a point [possibly] higher than it might see with the actual pump that the valve is set to simulate.
An Iwaki may well be able to exert far more pressure (far being relative to pumps) in this zone of tubing than an actual Eheim, even though the valve was set to what an Eheim might be rated for.
See what I mean?
True, very true.BillA said:sorry Ben, wrong again
"Measuring "W" is relatively easy, with the right tools (volt and amp meter)."
- this is a measurement of the power applied to the heating element, not the heat input into the wb or hsf at all
be cool
