over at http://www.overclockers.com/forums/showthread.php?t=700573
I started with wondering about upgrading an aging PC. The conversation has turned into an overclocking question since I was able to get a pc with a 555BE and MSI motherboard that was stable to so awesome clock speeds.
The new thing though is I happened upon a 960T and a better ASUS motherboard and now I am wondering which chip I should keep and which I should sell!
The motherboard is an ASUS M5A97 I am cooling with a CM V8
The CPUs are:
A 555 BE that is stable @ 1.384v with all 4 cores unlocked and at 4.2GHz I would be running the thing at 4.0GHz for safety's sake.
The other CPU is a 960T which I am currently running at 3.7GHz and 1.356v
I have not locked the cores back and gone for its max with only 4 cores yet I am guessing that one I find that then that is what I set the turbo mode up as? I believe I can set the turbo mode to switch from 6 to 4 and increase the vcore right?
The situation here is that I can only keep one of the CPUs. I have not found the limit of the 960T yet and on AIR I feel that I do not want to exceed 4GHz on the 555 which I am 100% sure is stable at 4.2 as I had it running prime blend for 2HRs and the only concern is that with prime on the high heat mode it does get up to 57c on the chip not the cores which I believe are about 10c lower but you are in the blind when you unlock the cores.
So for games performance wise which of the 2 is the better guessing that I will be able to hit 4GHz on turbo mode and guessing that turbo mode supports 4 cores not just 3?
The CPUs are:
