Hello,
first of all my config;
Asus P5nSlI
Intel Core 2 Duo E6300 conroe
Coolers: 2 80mm Case fans and a arctic freezer pro 7
3Gb kingston Pc5300
7600GT
Seagate 320 GB
Seagate 250 GB
Temp: 36C and 37C after stressing with prime95
I wanted to play NFS pro street but on my Intel core 2 Duo E6300 it didn't worked very well because my processor was just to slow. I installed it on a P4 3.0 Ghz and it worked perfectly. So i wanted to over clock mine E6300. So i went to the bios and set the AI over clock 10% higher. Came to windows, turned on prime 95, did the torture test and i'd get immediately an error: Rounding was 0.5, expected less than 0.4.
So i went searching for an answer but couldn't find one. I'm a novice at OC so please can someone give me a hand? my target is 2.5ghz
Asus P5nSlI
3Gb kingston Pc5300
7600GT
Seagate 320 GB
Seagate 250 GB
