waddupmm
In your bios you will see an option labeled " Spread Spectrum . Disable it
When you raise your FSB sometimes your AGP/PCI will also raise so you need to go back and lowerer it to 66/33 ( or the closest you can get as some boards will only alow you to set it at 67/34 when overclocked)
Before you start overclocking that Prescott what are the specs on your Power supply unit ??
Look for a label on the side and tell us the amps for the +3 , +5 and +12 volt rails
You can do some damage if this unit is not big enough for a prescott
Also as Ranger states you need to watch your temps as prescotts run hot
See my signature for some tips if this becomes a problem
Becareful and do not go crazy with raising the VCore !
Being a newbee I would not go above 1.5V with a prescott ( post your specs before raising it so we can be sure your system will handle it)
Good Luck and let us know the answers so we can help
Dave
