gettin a temp of 47c which isnt to bad I suppose,
Is this at idle or under a load?
i guess ill have to get rid of this stock heatsink get a better one,
Dont waste your money . Check out the link in my signature as it is my case .It does not matter what kind of heatsink ( using air) you have , if you don't feed it cool air you will not see any changes
A prime example of this is my system . When I first installed my prescott I had idle temps of 60C and load temps of 70c
I added the duct mod described in the link and my temps dropped like a rock using my stock HSF unit that came with the chip!
Inseach of even lower temps I purchased an SP-94 and a 92 MM panflow and did not absolutely no diffence in temps
My point is like I said above , if you feed the stock unit cool air and are not going crazy with your Vcore then you should be fine
Well I wouldnt call it stable it boots windows with it but when I run prime 95 I get these damn errors sayings its 0.5 expected 0.4 or somethings like that, and its kinda strange when I overclock comp seems slower to me not faster
It probably is running slower as Dynamic VID might be kicking in
Were you able to find the "Spread Spectrum' setting in your bios and disable it yet?
Do you have performance settings ?? IE turbo, Fast, Slow???
Do you have your memory set to 2.8V?
If so back down the FSB in small steps until it runs stable
Dave
