guys, he has the stock cooler and he needs to disable the cpu fan in bios.
I rebooted my computer, pressed F12 and entered the setup. Now all i get is a black screen ? Looks like my BIOS is gone !!
Test with a multi-meter to get actual votlage values... software = dubious.
Couple of things.
I use Gigabyte boards.
Install ET6. It will report accurate CPU temps. HWmonitor and Coretemp all read 10C low for my board (UD7) and I would suspect yours may be similar.
His temps are already way high and you are saying HWMonitor is reading too low. Well he is for sure very hot if HWMonitor is showing 10c low.
RGone...
Okay Johan i went inside my bios and i found the option cool and quiet and disabled it.
After i did that i managed to find the fans. I only had the option to tweak system fan 1 and i did not have any turbo mode. Just Normal, silent, manual or disabled. what should i do ?
QUOTE]
I would think the CPU fan mode could be set to manual and may give you options then . If all you have are normal silent and disable I would choose disable and the fans should run at full speed then.
