So you see the topic that I have. When I first put this machine together everything went smooth. Then recently I picked up a Z170X-UDA5 Gigabyte motherboard from the classifieds section (thanks again Zuzzz) which was originally used as a review model on this website! Here is the current system loadout
I5 6600K at 4.6Ghz (Core Voltage set to 1.36 in bios but showing 1.356 in CPUZ)
8 gigs DDR 4 ram at 2400 Mhz
240 Samsung M.2 SSD
Geforce GTX 1080 TI with power limit set to 90% in MSI Afterburner (stupid hot here and I find a 10% power drop = at most 1FPS in games but a drastic decrease in temp/noise)
Netgear A6100 USB Network Adapter
Windows 10 Pro with Windows 9.5 settings/changes per Linus-Tech-Tips
As my title states, now that I'm overclocking the system it seems stable enough, ran 4 hours of Prime95 and the hottest one of the cores hit was 79C, and no system crash. The system doesn't crash when playing games either. But every time I reboot the system the system wifi go's away and i need to reinstall the drivers to get the wifi to show back up down in the taskbar. I am using the default windows wifi manager.
Any ideas? Maybe I damaged windows somehow while overclocking (had a few reboot issues until I pumped up the voltage at 4.6 at first) and its whats causing the issue? Like I said nothing else seems wrong, everything else seems to be just fine. But it is a bit annoying having to reinstall every time before I can go online.
Oh, and setting my OC back to default doesn't fix the problem, it still requires a reinstall after every reboot.
If there is a better location for this tread let me know, but I didn't really see any. Thanks.
240 Samsung M.2 SSD
