Hello this is my first post and first major attempt at overclocking
i just finished upgrading my computer with a new mobo and cpu and was looking forward to overclocking them.
The specs on it are:
Dual Core AMD Opteron(tm) Processor 170
and a 939Dual-SATA2 with the newest bios.
Ive got the cpu with a slight overclock at 2.2 GH but i was wondering how far theoretically i could go with this setup.
To my understading to overclock these I would be changing the voltages, FSP, cpu multiplier and the HTT multiplier.
Any insight is greatly appreciated
For futher specs on how it is now here is a cpuz dump info:
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Opteron 170 (UP)
Codename Denmark
Specification Dual Core AMD Opteron(tm) Processor 170
Package Socket 939
CPUID F.3.2
Extended CPUID F.23
Brand ID 44
Core Stepping JH9-E6
Technology 90 nm
Core Speed 2200.9 MHz (10.0 x 220.1 MHz)
HT Link speed 880.4 MHz
Stock frequency 2000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 10.0x
max VID 1.400 V
Features XD
K8 Thermal sensor yes
K8 Revision ID 4.2
---Chipset -----------------------------------
Northbridge ALI M1695 rev. 00
Southbridge ALI M1563 rev. 70
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 3072 MBytes
Channels Dual
Memory Frequency 183.4 MHz (CPU/12)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Command Rate 2T
Display Adapter(s)--------------------------------------------------
Device number 0
Name GeForce 8800 GT
Vendor ID 0x10DE (0x3842)
Model ID 0x611 (0xC800)
Revision ID 0xA2
Perf Level Uknown
GPU core clock 738.0 MHz
GPU shaders clock 1845.0 MHz
GPU memory clock 1032.0 MHz
GPU temperature 51 C
Codename Denmark
Package Socket 939
CPUID F.3.2
Extended CPUID F.23
Brand ID 44
Technology 90 nm
FID/VID Control yes
max FID 10.0x
max VID 1.400 V
Features XD
K8 Revision ID 4.2
Memory Type DDR
Channels Dual
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
DRAM Idle Timer 16
Command Rate 2T
Device number 0
Revision ID 0xA2
Perf Level Uknown
