Hi Guys,
I understand overclocking and how to do it. My question is will I benefit from it and is it worth it.
I play IL2 Forgotten Battles and my system ran the game super when I had the old monitor and ran at 1280X resolution. I could crank the graphics and she was smooth and real. I bought the new Samsung P2450 and she doesn't like to run at 1920 X 1080. The graphics card is an EVGA GeForce GTX 460 (Fermi) 1GB GDDR5. So it should handle the game and the monitor. Here is the rest of the system,
MB is ASUS M2N-E AM2 NVIDIA nForce 570 Ultra MCP ATX AMD Motherboard
CPU is AMD Athlon 64 X2 4600+ Windsor 2.4GHz Socket AM2 89W Dual-Core
RAM is 4GB of G.SKILL 240-Pin DDR2 SDRAM DDR2 800
I assume overclocking the RAM is no good since the MB doesn't recognize anything faster? How about the CPU. If I overclock the CPU how far can I go with the stock heat sink and will I gain anything from it? I'm thinking the CPU is my issue right now??? Is overclocking the BIOS the best or use one of the utilities that came with my MB?
Thoughts?? Thanks!
Bubi
Thoughts?? Thanks!
Bubi
