- Apr 16, 2004
Hey fellas!
I am overclocking my C2D e6400 with the L2 revision. And well I'm running into some strange things here. I can have the C2D running at 2.8 Ghz (7x multi 400mhz fbs) and it is totally stable at 1.4v. But the second I try to push it further, say 3 ghz (380 x 8) I have to push the Vcore to 1.515 to get the thing stable, CPUZ reports 1.4v. That does not seem right for me, especially not when I compare with other overclocks that run on say 1.3 at 3.2ghz.
Whats the big differance between the B2 revision and the L2 revision? And is it ok to push the Vcore that much? My temps are not good but ok (28/idle 55-58/load depending on room temp)
my gear:
e6400 revision L2
ASUS P5B-E plus
OCZ urban 800mhz 4-4-3-15 2.1v
good airflow in case cpu cooled with crappy Zalman 9500 (getting a new one if I have to)
my gear:
e6400 revision L2
ASUS P5B-E plus
