- Jul 27, 2004
- Belton, MO
I bought a 512MB stick of Geil Ultra-X a couple of months ago, so it should use the UTT-BH chips. I'm having trouble getting good results out of it, but I am not sure if it is the RAM or the memory controller.
I was running it at 2.7V @ 195 2-2-2-5 1T no problems. I could get it a little over 210 with up to 2.9V, but that was it.
Today I got an OCZ DDR Booster so that I could go above my motherboard's 2.9V (Chaintech VNF3-250) vdimm max. I originally put the Booster in DIMM 1, with my RAM in slot 3. I was able to boot up to about 238 MHz 2-2-2-5 with around 3.6V, any less and it would freeze in the BIOS.
I then switched them so the Booster was in slot 3 and the RAM was in slot 1. This gave me about the same results. I decided to do some testing with Memtest. I noticed that anytime I was running ~225+ at 1T it would not pass even the first test in Memtest. I switched it to 2T, and it was fine. Using 2T, I was able to boot up to ~250 2-2-2-5, with around 3.4-3.5V. I had trouble much above that.
It froze while I was running Memtest at 250 2-2-2-5 2T, so I bumped up the voltage a small amount, and now it seems fine.
Shouldn't this RAM be capable of running quite a bit faster? I have messed around with it more than I said in this post, but I am trying to keep it somewhat short.
I don't have a lot of BIOS options to tweak; I have the basic timings, skew adjust, drive strength (2x or Normal), and a couple other things.
Can anybody recommend some settings that I can try? Or any other ideas?
Thanks
BTW, I have a 120mm, ~96CFM fan blowing directly on the RAM.
Thanks
