- Dec 14, 2010
The bios settings seem terribly limiting (even to me coming from an entry-level/mid-range DFI board), vCore maxes out at 1.55V on most recent bios (1805) and on bios revision 1013 (as well as 1010-001 and 1016 IIRC), I had to downgrade to 1003 before I saw an option for 1.6V+ (but that went so far back that it didn't have support for most of my CPU's). It's not unusual for me to need to pump 1.6V+ through a CPU to get it to the desktop and snag that screen capture for a CPU frequency submission, so this is really unacceptable. Sure the average user won't likely need much over 1.55V, but then again most of us around here don't qualify as being average users. Sure I'm not a hardcore sub-zero bencher that needs 1.8V+ to reach some crazy-high clock speeds, but it'd be nice to get at least 1.65V as an option without having to downgrade to an older bios, or worse yet having to switch back and forth between bios versions for benching one age of CPU's versus another.
To make matters worse I cannot find any settings for chipset voltage, and I believe memory voltage maxes out at 2.8 or 2.9V (though that's less of a problem for me since I rarely go past 2.8V being that I use TCCD memory most of the time when I'm overclocking or benching).
Is there some tweak I'm missing that makes overclocking on the Asus nF4 SLI boards easier?
Then there's the layout, if one wishes to use an aftermarket heatsink for the chipset they will be very limited in what will fit. I used a Thermalright HR-05-SLI because it was the best of what I had on hand that actually fit, but the problem is that with this board no matter how I mount it I will be unable to use one of my PCIe x16 slots, so no SLI. I thought about using a SilenX IXN-40C cooler, but that one prevented insertion of video cards in both of the PCIe x16 slots. *sigh* On the bright side though the aftermarket Thermalright cooling solution does work much better than the stock HSF, idling in the low to mid thirties as opposed to the high-thirties to low-forties with the stock HSF.
