Hello,
So I'm new here and made the account purely because I'm a bit confused as to why I'm blue screening when overclocking so wanted to ask people that know a lot more about it than me.
I can take my Cpu to 3.975 ghz without any problem but the moment i go 4 ghz or over I blue screen and the pc restarts. Voltage 1.4v (crashes whenever I try to change the voltage)
I can take the built in gpu to 1.25 ghz without any problem but the second i push it to 1.3 ghz I again blue screen. (1.1 voltage again crashes whenever I attempt to change the voltage)
I'm unsure if I'm doing something wrong or if this is just the max I can take it to which is weird as I've seen multiple times this cpu can be taken to 4.5 ghz and the gpu to 1.6 without any issues, I'm using the stock cooler but even under a stress test the temp isn't an issue.
Specs:
Cpu - Ryzan 2200g 3.5 ghz using the built in Gpu.
Motherboard - x470 AMD gaming plus
Ram - G.skill - Ripjaw V series 2x 4GB 2400
Psu - GVGA 600W 80+ ATX
Not really wanting to push it to the limit but was hoping I could get a little bit more out of as it seems it isn't even trying just blue screening 5seconds after changing the settings over the aforementioned settings before I can even attempt a stress test.
Any advice is welcome
Thanks in advance.
Specs:
Thanks in advance.
