Overview:
Some thoughts on choosing PSU for overclocking recent motherboard, CPU, GPU, ... (page 8)
What size PSU do I need?
Let's do some estimates. An estimate is better than just guessing, if it is not correct, we can refine it. By doing calculation, I find out the main demand is on current, and not on the total power that most people seem to emphasize on and pay attention to when looking at PSU:
E.g. Tbred B 1700+ DLT3C, 1.9V 2.5 GHz
CPU current = 71 A max, power = 135 W max
At rated, CPU current = 29.9/32.9 A, power = 44.9/49.4 W (typ/max)
It is the
largest component in a system.
fan ~ 0.2 - 0.7 A, 12 V
HD ~ 1.3 A (WD 120 GB 8 MB), 12 V
CDRW, DVD ~ 1 A, 12 V
I tried but cannot find spec for the following, so just making some guess (they are not big number compare to CPU, so end result should not be much different if guess is off).
mothboard = 40 W (includes NB, SB, ports, floppy, ...)
9700/9800 pro video card = 45 W (GPU load) + 15 W (card)
memory module per dimm = 3A @ 3.3V ~ 10 W
So assuming system as follow (assume air cool, adjust according for extreme cooling):
1 motherboard = 40 W (10 W 3.3 V, 30 W 5 V)
1 overclocked CPU at 1.9 V 2.5 GHz = 135 W
2 memory modules = 2 x 10 W = 20 W (3.3 V)
1 AGP video card (such as 9700/9800 pro) = 60 W (15 W on 3.3 V, 30-45 W on either 5V or 12 V)
1 CPU fan = 8 W (12 V)
4 case fans = 4 x 4 W = 16 W (12 V)
2 HD = 2 x 19.5 W = 39 W (0.8 A 5 V, and 1.3 A 12 V)
1 DVD = 12 W (1 A 12 V)
1 CDRW = 18 W (1.2 A 5 V, 1 A 12 V)
Total = 348 W
You may adjust these numbers according to your system, and level of overclocking. For good design, you may add 20% tolerence, or you may agrue some PSU's have hidden juice to cover this.
The above assumes overclocking as specifed above. If you don't overclock, then the CPU component would be smaller; ~ 85 W can be taken off based on my estimate. Or if you plan to overclock Vcore to 2.0V or above, you have to add more.
CPU active power and current are the major compoent due to overclocking. One thing to be careful is about the current on either the 5V or 12V PSU rail. This is the
major current number you have to go after at the spec of the PSU whether they can source enough current for stable Vcore for CPU plus other peripherals.
Besides looking for sufficient power reserve, one thing important is to look at the
current rating for sourcing CPU current and whether that line has tight regulation (1% vs 3% vs 5%) to proviode stable line for Vcore stability, and hence oc stability. For AMD mb, some mb's use 5V and some use 12V to generate Vcore.
1. If mb uses 5V to generate Vcore (e.g. A7N8X), the 71A will draw about 1.25 x 71 x 1.9 / 5 = 33.7 A on the 5V line (assume regulator efficiency 80%). Then
5V_current_rating > 33.7 + current_for_other_5V_components
Also assuming video card uses 30W on 5V
current_for_other_5V_components ~ (30 + 30 + 8 + 6)/ 5 = 14.8 A
Total 5V current requirement = 33.7 + 14.8 A = 48.5 A (if both Vcore and video card use 5V)
So if both CPU and high end video card use 5V, it is very overloading the PSU !!!! That is why it is highly recommended to get a motherboard that derives Vcore from 12V. Best scenario is motherboard uses 12V for Vcore, and video card uses 5V for GPU (I think the 9700 uses 5V for GPU).
2. If mb uses 12V to generate Vcore (e.g. NF7-S, 8RDA3+), the 71A will draw about 1.25 x 71 x 1.9 / 12 = 14.3 A on the 12V line (assume regulator efficiency 80%). Then
12V_current_rating > 14.3 + current_for_other_12V_components
Also assume video card uses 30W on 12V
current_for_other_12V_components ~ (30 + 8 + 16 + 31 + 12 + 12) / 12 = 109 / 12 = 9.1 A
Total 12V current requirement = 14.3 + 9.1 = 23.4 A
0308 finding - Video cards (9700/9800) mainly use 5 V for GPU:
current_for_other_12V_components ~ (8 + 16 + 31 + 12 + 12) / 12 = 79 / 12 = 6.6 A
Total 12V current requirement = 14.3 + 6.6 = 20.9 A
Add: If video card does not use 12V, then the 12V current would still be around 21-24 A, depending on the number of HD's.
E.g. I estimate a system that uses 12V for Vcore, with a Tbred B 1700+ DLT3C oc to 2.5 GHz 1.9V, 4 HD's, 1 DVD, 1 CDRW, 4 case fans, 1 CPU fan, 9700 video card, .. would require about 23.5 A on the 12 V line.
From the above calculation, it looks like as far as wattage, one can agrue any good 350 W power supply will do the job.
But due to the high current requirment of the CPU and GPU, the main demand and requirement are shifted to current requirement, and not just on wattage.
For new nforce2 motherboard such as NF7-S and 8RDA3+, they both use the 12 V to generate Vcore, which I think is better for more stable Vcore. This put the main demand on PSU for overclocking.
Let's look at some popular PSU on 12V line:
Fortron 530 W = 18 A (line regulation 5%)
Antec TP 430 = 20 A (line regulation 3%)
Antec TP 480 = 22 A (line regulation 3%)
Antec TP 550 = 24 A (line regulation 3%)
I am not going into the reserved power, hidden juice, ... debate of which PSU to get. You can use these numbers as guideline and make your own decision.
Some useful design points:
1. A P4 1.8 overclocked to 2.4 GHz 1.675V, 4 HD's, without highend video using 12V, ... (~ 20.8 A)
link.
Originally posted by hitechjb1 (06-21-2003 11:53 PM)
I try to estimate what 12V current you need:
P4 1.8a overclocked to 2.4 GHz @ 1.675 V
from spec 1.8 GHz 1.75 V Icc = 50.6 A
At 2.4 GHz, 1.75 V
Icc = 50.6 (2.4) / 1.8 = 67.5 A
power = 1.75 (67.5) = 118.1 W
At 1.675 V
Icc = 67.5 (1.675/1.75) = 64.6 A
power = 1.675 (64.6) = 108.2 W
The 12 V current for Icc assuming 80% efficiency on Vcore regulator
I_12V_1.75 = 1.25 x 67.5 x 1.75 / 12 = 12.3 A if Vcore = 1.75 V
I_12V_1.675 = 1.25 x 64.6 x 1.675 / 12 = 11.3 A if Vcore = 1.675 V
4 HD = 1.3 A x 4 = 5.2 A (based on WD 120 GB 8MB, 12 V)
4 fan = 0.4 A x 4 = 1.6 A (typical fan 0.3 - 0.7 A, 12 V)
CPU fan = 0.7 A (12 V)
1 DVD = 1 A (12 V)
1 CDRW = 1 A (12 V)
So 12 V current
12V_current = 12.3 + 5.2 + 1.6 + 0.7 + 1 + 1 = 21.8 A (Vcore 1.75 V)
or
12V_current = 11.3 + 5.2 + 1.6 + 0.7 + 1 + 1 = 20.8 A (Vcore 1.675 V)
Let's assume motherboard, video card do not drawn from the 12 V line at all. The power for them on the 3.3 V and 5 V is not significant.
Others (5 V or 3.3 V)
Mothboard = 40 W
2 memory = 2 W
1 video card = 30 W (7500 AIW not using 12 V ?)
So the main thing to look at is the 12 V current which is the most important number to look at. You will need a PSU that can supply about 20.8 A on the 12 V line. This is my estimate, pls take a look at it, comment and check the calculation are welcome.
In another thread, I have done similar calculations for powering recent systems. I found that we should pay attention to the 12 V current rating instead of just pure wattage in the PSU. I did some calculation in another thread, in terms of power 350 W should be enough. But as far as 12 V current, the story is very different, many PSU may not have sufficient 12 V current.
So please check the 12 V current rating of your PSU, and see whether it can supply the above current estimate. Does the above current estimate reflect your system reality.
If you have any question, pls post.
2. P4 2.8C overclocked to 3.7+ GHz, 9700 pro, 2 SATA HD's, fans, ..., 12V current ~ 20 A
link.
Originally posted by hitechjb1 (07-20-2003 09:37 AM)
Let's look at the 12V current. From the Intel P4 data for a 2.8C at rated 1.525V, Icc is between 23 to 55.9 A. I estimated when overclocking to 3700 MHz at rated Vcore 1.525V, the current would be somewhere betwen 66.5-73.9 A. For P4 and any CPU, around max overclocking, raising Vcore (than necessary) may make things worst. If raising Vcore to 1.6V, at 3700 MHz, the max current would be somewhere between 69.7-77.5 A. And it would translate into 11.6-12.9 A on the 12V line of the PSU (assuming 80% efficiency).
Assumiing each HD takes about 2 A on the 12 V (I don't have the detail spec for the SATA HD). The few fans take 1-2 A on the 12 V line. The optical drive takes 1 A. So the max total 12 V current would be around 20 A. The TP 480 PSU is rated 22 A on the 12 V.
3. P4 2.4C overclocked to 3.4 GHz 1.6 V, 1 HD, fans, ..., 12V current ~ 18 A (2 HD's would be 20 A)
link.
Originally posted by hitechjb1 (07-22-2003 09:27 AM)
The major demand on PSU for your system is the 12V current due to CPU, HD, CDROM, fans, ... from your list. Let's do some estimate.
P4 2.4C at rated 1.525 V, the current is between 23 - 52.4 A (from data sheet). At your target frequency of 3.4 GHz, I estimate the max current would be somewhere between 64.7 - 74.2 A at 1.525 V. In case you have to raise the Vcore to 1.6 V to acheive the 3.4 GHz, I estimate the max current woudl be between 70.0 - 81.7 A. At 1.6 V Vcore, assuming a 80% efficiency Vcore regulator, it would draw a max current around 11.7 - 13.6 A on the 12 V line of the PSU.
Other 12 V current are: 2 A per HD (average), 1.5 A for the fans, 1 A for CDROM drive. So the total max 12 V current is estimated to be around 18.1 A.
Other the current and power for the 3.3 V and 5 V should not be a concern.
The 12 V current estimate of 18.1 A is already higher than the rated current of most 350 W solid PSU. If you need to add a HD in the near future, it would be about 1.5 - 2 A more per drive, and bring the 12 V current requirement to 20 A. I estimate for a typical overclocking P4 and AMD system that use 12 V for Vcore, the 12 V current requirement is at least 20-24 A (from a variety of cases).
Even if taking some potential hidden reserve of a PSU into account, due to overclocking of the CPU, the 12 V line current rating of most 350 W PSU is working at the edge of, or slightly below your system demand. If you already have the PSU or on an absolute budget for a 350 W, then try it first and it may just limit your CPU overclocking by 200-300 MHz. If you plan for some growth for your system, I would get a solid PSU with 20-24 A on the 12 V, possibly with smaller line regulation.
