- Mar 7, 2003
doesnt seem to clock any higher.... prime crashes.... i think its cause that the heat is to much... i ordered the SLK900U should be coming wed or so
2.3 barton is pretty good tho
Audioaficionado said:I wished I'd gotten the SLK800U or 900U instead of the Vantek TMD fan HS. Now I've wasted $30 and may have wounded my CPU's top end o/c.
I'm getting one as soon as I can afford to spend the $70 bux.
kamz said:the code i got is 0307, i have tried higher volts even 1.8 but the system crashes or sumtimes wont boot after exiting bios... mayb some of my settings are wrong in the bios...
ps what is socket wiring trick???
hitechjb1 said:
Do you have a NF7-S rev.2, it can go higher Vcore, so wiring trick is not needed as someone already pointed out.
What temp did it crash at 1.8V? What PSU do you use?
OrionRU said:Hmn i still got all my multi's with 14b1 bios...
