- Feb 10, 2011
- The Netherlands
Hey all!
I recently purchased the H80 from a local vendor here in The Netherlands and have installed it in my system. You can see more specs of my system in the sig. So what I'll be doing in this thread is going over temps and what I'm able to achieve in terms of overclocking with this I'm very excited to get started on this as it is the first time I've gotten into watercooling. It's definately not going to be able to compete with those custom water cooled loops however this is maintenance free. I'm not saying custom water cooling requires constant maintenance and fiddling but with the H80 you can literally slap it in your grannies system and not worry about it.
I'll show some pictures of the system aswell as what type of airflow my case has to offer shortly in a later post. There are lots of variables that can change results slightly from a system to system. So please take my results with a grain of salt.... or mix it with some sugar..
So for those wondering what the Corsair H80 is you can probably google it to get a good idea of what it is. But for those too lazy, it features a rather thick 120mm rad with two fans for a push pull. It is pre-filled/pre-sealed and the pump and other electronics are inside the waterblock. The H80 is a more refined version of the H70 where the waterblock is updated, not sure on the radiator (google should solve this). On the waterblock there is a button to control the fan speed to meet your cooling requirements, it does start getting loud though.
I will now and then compare my overclocking results to my old cooler, namely the Scythe Mugen 2-B. I was able to achieve a 4ghz overclock with this before hitting a wall where temperatures just didn't allow me to keep going. I was at a 43-45c idle and getting close to 90c load. Hopefully the H80 can releive this and allow me to push a good bit further while keeping everything under control. I am using the pre-applied thermal paste on the H80. On the Scythe Mugen I used the thermal paste that came within the packaging.
In the next posts I will talk more about my overclocking results and temperatures.
P.S. Is this what would be called a "Project Log"?
