So I've been using this computer without heating issues for over a year. I boot it up after a day of no use and the screen says overheating processor at launch. I go into the BIOS and it says it's 97, 98 degrees C. So either I shut it down or it goes off itself.
I have an H70 (which I plan on replacing cause I've been getting not-so-good temps for a while), an Asus Sabertooth P67, a Corsair GS800, and SLI 570s.
I have been using an assist fan on the Sabertooth for a while now, and it was fine. It started to rattle so I ordered a new little fan online. The reviews said it worked fine on my mobo, so I went ahead and installed it. It's of course a 12V fan, but it's .15A instead of .09 on the other one. Could that have fried my mobo somehow?
I also reset the CMOS/BIOS by using the little jumper plug, just in case the voltage was raised somehow. This undid the overclock someone did for me, but I don't mind.
I know you will all say that I need to reseat the CPU cooler, which I will, but could it have gone from 45 degrees idle to 97 degrees in BIOS over a period of 48 hours? Even after a year of working fine with the same paste on it and everything?
Thanks for the help, if you reply. I'm at a loss.
