- Mar 27, 2007
8. P5B BENCHMARKS SLOWER AT HIGHER SPEEDS: BleedinEdge member Tony has an in-depth analysis of why higher FSBs can benchmark significantly slower memory bandwidths than much lower ones. For example, in his studies, he systematically proved that a 400MHz FSB is just as fast as a 460MHz FSB on this motherboard, and that a 400MHz FSB can deliver 500MB/s MORE memory bandwidth than just a one megaherz increase to 401! This issue, put simply, relates to the way the chipset (Which is like a very simple CPU) clocks itself based off your FSB with internally-set (And indirectly-controllable) multiplier. Essentially speaking, AVOID A 360-399MHz, 401 and 401-460MHZ FSB AT ALL COSTS. If you intend to overclock, get PC2-8000 and push for 475+ for high CPU clocks, or settle with a 400x6/7/8/9 clockspeed depending on your CPU for maximum performance. Not following these guidelines will not only rake your memory bandwidth over the coals, but also introduce SEVERE instabilities as the chipset (Northbridge) tries to run at too great a clockspeed.
Taken from: http://icrontic.com/forum/showthread.php?t=50712
I just found this, the post was from a long time ago (2006), but is there still any truth in that?
