This occurs also without OC
Hi Gents
I'm new here.. Also english isn't my native language.
My problem is following - only that all of the posters here don't feel alone...
Have also a very good knowledge of Computers and the wherabouts. I usually never Overclock because the input effort does'nt match the outcome. So I stay with Stock Speed etc.
Board - P5B-Deluxe Bios 1226
CPU - E6700 @2.66Mhz 2*4mb cache
Ram - 4GB Kingston KVR800D2N5K - PC6400 -
VGA - ATI EAH-3450 / 256 mb PCI-E
Drives - SATA WD 160Gb *2 Boot Drive WinXP - Pro Also Win Vista
Drives - SATA Hitachi 72GB * 2 Boot Drive Win2k
Drives - SATA Maxtor 300 GB Boot Drive Win2k
This Problem - Trashed System Files usually SYSTEM or SOFTWARE - Registry files - only concerns for the Win2k Drives and only the Hitachi and WD drive if there is Win2k Running. No problems on WinXP or Win Vista
Since the Graphic adapter is official supported by ASUS but it will not install on this maching there was a small INF tune necessary to have it install on win 2k. The driver itself works fine.
I'm no Gamer and so there is ne need to OC. All I use this machine for is for regular Business and may a bit music and also Movies & creating DVD's.
The Win2k were running on a P4P-E Deluxe prior to the Switch on the P5B
Win2k was running smooth as a baby *** never any problems.
The transfer to the new system was also without any problems except as stated above the Grapic controller wouldn't install without INF Modification..
Call it a badly written INF file..
If for any reason the Win2k stops responding with a BSOD the next I know is DATA Corruption on the Win2k Drive .. It will not happen if I use a IDE drive.
Everything is BRAND NEW on this computer - the drives were all working without any problem.
Have running the System on PERFOMANCE of the FAN Speed or Quiet the it will occur. If I change the Fan Speed to MAX then it will Occur but much less.
But I'mSure it isn't a heat problem - hardware probe shows 45 C for the CPU and even less for Chipset..
Any one has a IDEA? BTW I think it has something to do with the Southbridge..have seen this before on HP Computers.. but actually never found the reason for it.
Regards and Thanks
Chris
