The issue was fixed for P67 as long as it's a B3 revision board. The only thing wrong with it was a small problem with a few of the SATA ports though...just had to make sure you had something like a CD drive hooked up to those ports and not a HDD and you'd be fine.
Main differences between P67 and Z68 are the ability to use the onboard video, SSD cacheing, and Ivy Bridge support.
None of the P67 boards still on Newegg look particularly good.
There's the Gigabyte Z68XP-UD3, which has a 7 phase and should be decent. Otherwise, I'd try going for the open box ASUS P8Z68-V Pro or the MIVG-Z.
However, all Z77 boards should work with Sandy Bridge CPUs...much easier to find.
