- May 28, 2012
Hello,
First of all let me say I've not O.C. sence way back when.. I just finished the 3 step guild on how to O.C. an heres my problem.
I'am using a P6T Asus Motherboard bios ver 1408 with a i7 960 3.2 Ghz chip
12 gigs of Kingston ram KHX 1600C9D3K3/12gx timings 9-9-9-27
in bios all power saving off,stepup off all like the guide suggest. using memtest 86 iam able to set the ram at 1600 in bios an get a pass on all cycles. when I load windows 7 an run CPU-Z shows DRam Frequency 804 Mhz FSBRAM 2:12 which it should be NB Frequency 3200 MHz at idle every thing is good but when i use Prime95 an put a load on the system In-Place Large FFT it runs for about 2 mins an freeze the system hard lock. Now if I go back an set the Ram to 1333 MHz in bios my Dram Frequency in CPU-Z is now 667 MHz 2:10 FSB DRAM an NB Frequency drop to 2671 MHZ an I can re-run the test an every thing is stable for hrs. What iam not getting how can my ram be stable in bios at 1600 Mhz an unstable in windows. My heat on Real Temp never reaches over 72 c with full load. I dont think its a heat problem. I set my Core Votage to 1.3 - 1.4 still hangs. my CPU Blc is 133 x 24 I dont want to over clock my cpu just want to get my ram stable at 1600 mhz. Any Help would be greatly apprecatied. PS the guide talks about seting the QPI/Dram to 1.3v to1.35v this I have at auto only thing I can think of that Ive not tryed.
