hey
actually you dont need to permanently attach anything.
all you need to do to the zalman is to remove the fittings for the push pins, and then from your old heatsink, pull off the spring thing, and just get it to fit on the zalman, obv making sure you've got good contact and theres a lot of tension in the spring.
my nb32j(the gold one) is running perfectly fine like this!
