- Feb 18, 2015
- Austin Tx
Has anyone ran the DH 14 with no fans on it?? Does it cool good enough? Ive seen a few builds using the Dark Rock pro from Be Quiet and they took the fans off. They were even running a i7 cpu as well.
I think ill only buy Noctua brand fans from now on.
well a 120mm is in the front now. Cant a 140mm round fan fit in a 120mm spot?
That's what they say. However, they sent me review specimens, so I have had them in my hands, measured their pull through filters, measured their push through rads. The comparison review is here. Note that the is not much difference between the NF-P12 and the NF-S12A in unfettered output. But put a filter on them, or a rad, and you get this. So, if you're going to get a Noctua 120mm case fan, get the NF-P12.
