- Apr 26, 2002
- Albuquerque, NM
Hello,
I can't totally figure out why my temps are so high. Here is my setup:
Asus A7V333
AMD Athlon XP 1800+ (stock voltage and clocking)
Thermaltake VOLCANO 6Cu
Matrox G450
Maxtor 7200 rpm 60 GB hard drive
Windows XP Pro
80 mm front intake fan
80 mm rear exhaust fan (plus PSU 80 mm fan)
Here are my current temps at IDLE in Celsius:
CPU: 58 (!!!) (on-die thermal diode)
Case: 31 (according to MB sensor)
Ambient: 27.0 (1" from front intake fan)
PSU Exhaust: 37.5
What I have done:
- Airflow through case seems decent, no ribbon cables blocking airflow
- Lapped the 6Cu to 600 grit
- Applied AS2 per Arctic Silver's directions
- Remounted HSF a few times with no change
I have noticed that the Vcore reads around 1.79 V rather than the 1.75 V it should be. This is according to the MB sensors. Where should I measure it to get an accurate reading? I have a really good Fluke DMM so it should be much more accurate than the onboard sensors.
What I'm looking for is for someone to say "you've got a problem" or "the 6Cu is just that bad". And any other advice, of course. If the Vcore is about 0.04 V higher than it should be, how many degrees increase could this be causing?
Oh, and I want my computer to remain relatively quite, so no "put a Delta on it" please.
Thanks,
John
P.S. I have all the parts for water cooling, but I feel a challenge to get the temps under control with air cooling first.
Asus A7V333
Matrox G450
Windows XP Pro
PSU Exhaust: 37.5
What I have done:
Thanks,
John
