- Jul 13, 2009
Thank you a head of time for your help.
I built my pc about a year and half ago and it has been slow to boot since day 1. I am running windows 7 64bit and turning on the computer takes almost 8 minutes to 10 minutes to get to where it is functioning. It is this way even if I disable all start up programs. I have a laptop that runs windows 7 and it boots in and is operational almost immediately so I think it is my setup. I will list setup below:
Field Value
AMD Phenom(tm) II X6 1090T Processor
gigabyte GA-MA790X-UD4P
4x2gig of OCZ ddr2 1066 ram ( i have tried with 2x2 and same issue)
NVIDIA GeForce GTX 460 (currently at 60 degrees C)
650 watt ultra power supply
500gig Sata Samsung HD502Hi ATA Device (this is partitioned but the main drive is the only one used others have been erased.)
The full summary from Everest utility is attached.
Thank you again if you see anything that sticks out this was my first build so not sure where I went wrong or maybe just thinking a six core 8 gig setup would be alot faster than my old Kathlon amd 1.8 512mb setup was wrong.
Field Value
